ae85 -> 20v fueling
ae85 -> 20v fueling
Postby spencer » Wed May 12, 2004 10:44 am
hey just wondering if its gunna be easier to use ae86 fuel pump with my 20v? does it bolt in or need the whole 86 tank? Or do I use origy pump into a surge tank then onto high pressure fuel pump, I already have a VL fuel pump sitting at home. Also with fuel lines should I find ae86 one or bend one up, I bent one up for my ke70 but was a mish.
ms63 crown
spencer
Postby Drifter4ag » Wed May 12, 2004 1:01 pm
if you can find ae86 tank + pump the lines already on the car should all bolt up. ae86 pump is more than enough for a 20v .. but for ease run a low pressure pump from your fuel tank into a surge tank then high pressure VL or similar into fuel rail.. its pretty easy
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Users browsing this forum: No registered users and 64 guests
