Interesting octane article
Postby Jools » Fri May 14, 2004 3:04 am
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Jools
Postby Ae92typeX » Fri May 14, 2004 11:56 am
Good read!,
heres afew bits some of you might be interested in (if ya cant be bothered reading the whole article);
Can higher octane fuels give me more power?
On modern engines with sophisticated engine management systems, the engine can operate efficiently on fuels of a wider range of octane rating, but there remains an optimum octane for the engine under specific driving conditions. Older cars without such systems are more restricted in their choice of fuel, as the engine can not automatically adjust to accommodate lower octane fuel. Because knock is so destructive, owners of older cars must use fuel that will not knock under the most demanding conditions they encounter, and must continue to use that fuel, even if they only occasionally require the octane.
Once you have identified the fuel that keeps the engine at optimum settings, there is no advantage in moving to an even higher octane fuel. The manufacturer's recommendation is conservative, so you may be able to carefully reduce the fuel octane. The penalty for getting it badly wrong, and not realising that you have, could be expensive engine damage.
Does low octane fuel increase engine wear?
Not if you are meeting the octane requirement of the engine. If you are not meeting the octane requirement, the engine will rapidly suffer major damage due to knock. You must not use fuels that produce sustained audible knock, as engine damage will occur. If the octane is just sufficient, the engine management system will move settings to a less optimal position, and the only major penalty will be increased costs due to poor fuel economy. Whenever possible, engines should be operated at the optimum position for long-term reliability. The quality of gasoline, and the additive package used, would be more likely to affect the rate of engine wear, rather than the octane rating.
What happens if I use the wrong octane fuel?
If you use a fuel with an octane rating below the requirement of the engine, the management system may move the engine settings into an area of less efficient combustion, resulting in reduced power and reduced fuel economy. You will be losing both money and driveability. If you use a fuel with an octane rating higher than what the engine can use, you are just wasting money by paying for octane that you can not utilise. The additive packages are matched to the engines using the fuel, for example intake valve deposit control additive concentrations may be increased in the premium octane grade. If your vehicle does not have a knock sensor, then using a fuel with an octane rating significantly below the octane requirement of the engine means that the little men with hammers will gleefully pummel your engine to pieces.
You should initially be guided by the vehicle manufacturer's recommendations, however you can experiment, as the variations in vehicle tolerances can mean that Octane Number Requirement for a given vehicle model can range over 6 Octane Numbers. Caution should be used, and remember to compensate if the conditions change, such as carrying more people or driving in different ambient conditions. You can often reduce the octane of the fuel you use in winter because the temperature decrease and possible humidity changes may significantly reduce the octane requirement of the engine.
Use the octane that provides cost-effective driveability and performance, using anything more is waste of money, and anything less could result in an unscheduled, expensive visit to your mechanic.
Ae92typeX
