What spring rate for 86 club car ?
Postby passenger pete » Fri May 14, 2004 6:21 pm
Any one with a ae86 or dx with any info for spring rates in a club car set up ? im useing 65mm springs on platforms i was thinking 300pounds maybe ?
passenger pete
springs
Postby fxgt race » Mon May 17, 2004 8:02 pm
not quite an ae86 but an ae82, running bilsteins coilovers with 270pound in the front ant 210 in the back .not much give on the road but works well on the track ,at times could be a little soft on the track but had to not go to hard as it is road registred and with the state of our roads shes a pretty hash ride.
fxgt race
Re: springs
Postby matt dunn » Mon May 17, 2004 11:51 pm
fxgt race wrote:not quite an ae86 but an ae82, running bilsteins coilovers with 270pound in the front ant 210 in the back .not much give on the road but works well on the track ,at times could be a little soft on the track but had to not go to hard as it is road registred and with the state of our roads shes a pretty hash ride.
Probably not a good comparosion as FWD and RWD are very different in setups.
You need soft in the rear to give traction but hard enough to provide good corner stability.
One of our race cars uses 180pound springs in the rear and the other heavier car uses 300's i think, and up to 500's in the front. These are track only cars.
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
