Even just front mounting the stock top-mount would be better than nothing
Rob wrote:I have got some alloy that I might try this with.
FLAWLES.... I think that the stoppage of the heat rising will work because The the air going through the intercooler will stop the heat soak by cooling the heat shield. Unless ur in traffic that is.
heat rise's right so putting a shelid uder the intercooler will stop a bit of heat for a litter bit then the shelid it shelf will heat up and do the same thing even worse
The fan thing was done by Autospeed.com, the guy said that it work well
