Compression ratios - how to work out???
Postby matt dunn » Tue May 18, 2004 12:45 am
Ok you math genius's..
Work this out...
4AGE 20V compression ratio.
Low compression dished pistons and modified head
CC is 1587
Piston combustion volume is 15cc
Head combustion volume is 35cc
Now head gasket thickness is 1.25mm
Need to convert this to a volume amount to work out volume
Bore size is 81mm
So somehow using 1.25, 81 and pie?? you can work it out.
Been a few years since i was at school.
Postby fivebob » Tue May 18, 2004 12:58 am
6.44cc for the head gasket volume, 8.03:1 CR
Formula for gasket volume is (bore/20)^2 x pi x thickness/10.
And I'm willing to bet it's been a lot longer since I went to school :D
