4 Throttle Bodies 4 Air Filters
Postby DOHMAN » Fri May 21, 2004 1:21 pm
IS IT WORTH PUTTING A AIR FILTER ON EACH THROTTLE BODY ON A AE111, DOES IT GIVE ANY ADVANTAGE THAN JUST HAVING 1 POD FILTER ON THERE, DO YOU HAVE TO PUT TRUMPETS ON THERE OR CAN YOU USE THE ORIGINAL BLACK TUBES THAT ARE ON THERE. THE OTHER THING IS THE FACT OF COLD AIR WERE DO YOU GET IT WITH 4 AIRFILTERS.
http://toyspeed.blakjak.net/profiles/profile.php?id=129
DOHMAN
Postby 4AGE 8U » Fri May 21, 2004 1:44 pm
yea it probably would be recommended but me and my mate's just have the factory trumpets poking up with no air filter at the mo till we get our 107mm bell mouthed trumpets made up. i found that u loss a bit of low end torque and gets a fair bit of hot air but other than that it sounds real nice aye.
4AGE 8U
Postby MrOizo » Fri May 21, 2004 1:55 pm
i think your shift key is stuck unless you left your caps lock on.. might wanna check them before worrying about throttle bodies :P
MrOizo
Toyspeed Legend
Postby Blkwinter » Fri May 21, 2004 4:34 pm
4AGE 8U wrote:yea it probably would be recommended but me and my mate's just have the factory trumpets poking up with no air filter at the mo till we get our 107mm bell mouthed trumpets made up. i found that u loss a bit of low end torque and gets a fair bit of hot air but other than that it sounds real nice aye.
You have an AE111?
Blkwinter
Postby DOHMAN » Fri May 21, 2004 4:55 pm
must of put you funny undies on today mroizo anyway thats not what im worried about, whats if you cant get cold air to the sperate air filters what advantage would you get over just having 1 pod with a cold air box apart for all the noise that it makes.
Yes I have an AE111
DOHMAN
Postby TRD Man » Fri May 21, 2004 5:06 pm
In our experience with quite a few of these you'd gain a couple of horsepower up top but you'd lose quite a bit of your driveability down low.
In short the thing would rev really freely and not go anywhere fast.
You're better of to stick with your CAI & single pod.
We're presently testing an item that we hope to make available which should improve mid range pick up considerably - at a reasonable cost. Keep watching.
TRD Man
Postby EVLGTZ » Fri May 21, 2004 5:22 pm
or you could check these out..... http://forums.toyspeed.org.nz/viewtopic.php?t=17141
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby DOHMAN » Fri May 21, 2004 6:00 pm
thanks dudes i didnt think that there would be much of an advantage except for all the noise it makes.
DOHMAN
Postby EVLGTZ » Fri May 21, 2004 11:10 pm
Robert Watson wrote:thanks dudes i didnt think that there would be much of an advantage except for all the noise it makes.
noise = advantage? wtf
EVLGTZ
EVLGTZ
Postby strap-on » Fri May 21, 2004 11:20 pm
got rice?
mayb thats ur answer
strap-on
Postby DOHMAN » Sat May 22, 2004 2:44 pm
more noise doesnt always mean more advantage dont forget the saying all noise no go i still dont see the point in seperate airfilters cause all they do is suck in the engine bay heat unless you design away to make a cold air intake for them the only way i can think of is if you make a bottom less box over the top of them.
what do you mean got rice?
DOHMAN
Postby diss7 » Sat May 22, 2004 2:49 pm
Robert Watson wrote: dont forget the saying all noise no go
Hvae you heard a Formula one car before? Or a Top Fuel dragsters?
When someone says all noise no go they're tlaking about vtec.
diss7
Postby DOHMAN » Sat May 22, 2004 4:28 pm
good call dude hondas are all noise no go still doesnt answer my question though is it worth the hassle putting seperate air filters on, there is one car down here in whakatane that has done it its a old corolla about an 85 maybe it has a silver top in it a link computer and sperate air filters dont know how fast it is doesnt actually make that much inductuion noise though.
DOHMAN
Postby EVLGTZ » Sat May 22, 2004 5:59 pm
Robert Watson wrote:good call dude hondas are all noise no go still doesnt answer my question though is it worth the hassle putting seperate air filters on, there is one car down here in whakatane that has done it its a old corolla about an 85 maybe it has a silver top in it a link computer and sperate air filters dont know how fast it is doesnt actually make that much inductuion noise though.
he can prob make the most of that type of setup due to having the aftermarket ecu and ability to tune it with that setup.
IMO with std ecu prob best off to stay with that cold air induction setup you have now.
EVLGTZ
EVLGTZ
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
