tough AE101 question - knocking noise
Postby marke » Fri May 21, 2004 8:46 pm
Hi all,
now i have a question that may sound stupid but its stumped me and the man from pitstop and my friends. i have an ae101 levin and its making a knocking around the corners. now i thought it was the cv so i took it in and the guy had a look at the 'boot' and said it seemed ok, he didnt look at the joint cause he thought he found the problem... he thinks its the back bumper as you can push it down and it does make a very similar sound. if i dont apply any throttle around corners (but ghosting it like that id have to do it slow to stop it knocking) then it wont knock and also the speed of the knocking is co-dependant on the speed i go around the corner...
has anyone heard of this? or had this problem before?
any help is appriciated.
Mark
No this is me in a nutshell..
"help im in a nutshell, how did i get into this bloody great nutshell... what kind of nut has a shell...like this.."
marke
Postby PumpN » Fri May 21, 2004 10:11 pm
sounds like ball joints, if i remember rightly they can only be checked when there is load on the wheels ie on a drive on hoist, they are a very common problem on super strut equiped levin/truenos
cv's make a clicking when the wheel is turned at a decent angle, could be shocks which tend to make a knock knock knock noise when you go over bumps (or push up and down on bumpers) when they get really stuffed or start leaking but you would notice it seeing as your passengers would need sea sickness tablets to ride in your car
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby Ae92typeX » Fri May 21, 2004 10:18 pm
had a knocking noise conering in one of my old cars cos one of the engine mounts had failed- have a look at them also
Ae92typeX
Postby aesc » Sat May 22, 2004 4:21 pm
Its kinda stupid, but it could be that the wheel balancing weight has been put on the inside of the rim and its knocking on the strut. On AE101s there isnt much room between the inside of the rim and the strut. Happened to me when i first got my car lowered. That would explain the knocking become faster depending on how fast your going around corners.
Otherwise, if you have super strut, could be the ball joint in the front, or sway bar bushes (fr or rr).
EX AE101 owner
2013 Ford Focus ST
aesc
Postby marke » Sun May 23, 2004 7:36 pm
cool thanks for the comments,
im pretty sure its not superstrut? whats an easy way to tell? i think its the cv joint its gotten louder over the last 2 weeks or so.. might just pay to have the suspension checked!
cheers for the advice!
mark
marke
Postby AceSniper » Mon May 24, 2004 1:27 am
another one is the hub nut... if u get a lil knock when ur slow an floor it in a high gear prolly b that they gota b pritty tight, semi common with ae101's
AceSniper
Postby RAZA » Tue May 25, 2004 6:53 pm
[quote="marke"]cool thanks for the comments,
mark[/quote
easy way to check is how big are your front brake calipers?
if they have one piston on each side then your car is non superstrut
if they have two on each side then its superstrut
Currently driving:
BMW 135i M
RAZA
Postby FLAWLES » Tue May 25, 2004 7:09 pm
or do they have a funny looking linkage atached to the strut
i would check out the ball joints and superstrut ends
FLAWLES
Postby 10k 20v » Tue May 25, 2004 7:30 pm
without hearing the noise its hard to tell but it has been known that the spider
gears in the diff to give trouble
10k 20v
Postby Adydas » Tue May 25, 2004 8:08 pm
better hope its not the super strut.. i hear that shits not cheap to fix..
Adydas
Postby Graphite » Wed May 26, 2004 12:20 am
I had a similar sounding problem with my AE111, took it to mechanics, and they couldn't get it to happen.
Turned out it was the Factory strut brace bolts, that attach it to the firewall were not tight enough, after I tightened them the problem vanished, even though Toyota told me it was probably the hub or something else making the noise.
Graphite
Postby matt dunn » Wed May 26, 2004 12:30 am
Graphite wrote:I had a similar sounding problem with my AE111, took it to mechanics, and they couldn't get it to happen.
I had that exact same problem with my AE111.
Postby marke » Thu May 27, 2004 8:10 pm
got sick of the noise and took it to Midas today.
found it out it was the left front shock being loose (dunno which bolts) the noise seems to have ALMOST dissappeared but i have to go back tomorow
>>so if anyone else gets this noise have a check of the suspension make sure everythings tight!<<
Mark
marke
Postby 10k 20v » Fri May 28, 2004 7:52 pm
sounds like the nut on the top the shock.
WE had a funny noise in a rav4 that was the top nut.
10k 20v
