mr2 radiator 2 q's
mr2 radiator 2 q's
Postby mister two » Fri May 21, 2004 10:33 pm
ok my radiator is leaking in the sw20
1. how do i get it out. does it come out the top or the bottom? do i need to take the fans off to get it out or not?. does the air con condenser need to be moved? (i know i cant disconnect it because of the gas)
2. how do i make sure that there are no air locks in the system when it is reinstalled, i know there is one valve that is on the radiator and apparently there is another one somewhere else? i dont really wanna crack a head because there is an air lock in the plumbing :?
(ok 3 questions actually)
3. how do ya fix a radiator once ya find the hole? is there a budget way that works? (i dont like paying to get things done unless i cant do it myself)
thanks in advance :wink:
Current ride = suggestions welcome
Previous rides = 89 BFMR 4wd Sedan, 73 Fiat 124 Sport CC Coupe, 71 ke26 wagon, 1990 mr2, 1988 rolla hatch, and a cough cough.. sigma
I can't be without my car, even when i'm in the club I drive to the bar!
mister two
Postby dodgy » Sat May 22, 2004 12:40 am
sorry dude, but if you cant figure how to remove the radiator the theres no way you should be considering repairing it yourself.
but anyway, it comes out the front.
when back together, you need to bleed it from thr front, then again at the head.
Get a hold of the repair manual, as it is avalible online, and read fully before trying anything.
Im not to sure, but i think i git the manual from http://home.kabelfoon.nl/~marcor/MR2links.htm
dodgy
Postby mister two » Sat May 22, 2004 2:37 pm
i already know that it comes out the front! i wanted to know top or bottom.
i wasn't gonna repair it unless there was a easy way of doing so.
i just wanna take it out so i can take it somewhere to get fixed and not have to pay them labour to take it out, unless there is a easy way to do it.
how does it get fixed when professionally done then.
there wasnt anything on that link of help. :(
okay i am gonna have a look at gettin it out this afternoon, im sure i will figure it out. just hadn't had time to have a good look yet.
but does anyone have a detailed description of how to bleed it? ie how to actually go about it.
mister two
Postby dotdog » Sun May 23, 2004 11:14 am
Dude, If you cant fix it yourself, there is a radiator shop on guyton street that fix them for next to nothin. Its just along from stewarts powerbase. Took my pulsar radiator there and the found the hole and fixed it for $10
Good luck
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby mister two » Sun May 23, 2004 11:15 pm
that sounds like the go. i have got it out and found the hole.
it cracked by the in pipe.
anyone know how to bleed it so i dont get an air lock?
and which coolant is best to use?
mister two
