n e 1 here knows how to fix this?
Postby m_O_O_m » Mon May 24, 2004 2:20 pm
Can n e 1 plz explain how horn switch on steering wheel works on EP91 Starlet Glanza V?
I got my starlie with no horn... I pressed the button but it ain't work... I just pulled out steering wheel... and I found two wires connected to the steering wheel...
1) Green wire [Steering Wheel -> Soldered to the place near the BOSS kit ]
2) Black wire [Steering Wheel -> snapped off about 5 cm long]
I am guessing that Black wire is snapped off and that's why my horn [cracktion] is not working...
I tried getting a + from the battery and attached it to the black wireand no... not working
I tried getting a - from the battery and attached it to the black wire... and no... not working
I tried searching the rest of the black wire which is snapped off but... no... couldn't find it....
Can n e one plz help? heh...
m_O_O_m
Postby Monsterbishi » Mon May 24, 2004 2:33 pm
The horn uses a normally open circuit, touch the two wires together and thy horn shall make sound...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby pacer » Mon May 24, 2004 8:40 pm
as jinkz said. its a break in the positive or negative side of the of the horn relay circuit
Toyota - Get the feeling
pacer
Users browsing this forum: Bing [Bot] and 11 guests
