Help! How do you install SC12 onto Engine... SOLVED
Postby Monsterbishi » Tue May 25, 2004 9:04 pm
Car 1986 AW11
My dilemma, I can't get the Supercharger and inlet manifold onto the engine togther without leaving the bottom inlet manifold bolts undone!
So, does anyone know how to install the Manifold, SC12 & Mount onto the engine while it's still in the car?
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Monsterbishi » Tue May 25, 2004 11:00 pm
Solved!
By removing the little studs on the charger outlet and replacing them with 10mm bolts from a spare camshaft cover which were identical in length to the other ones, we were able to fit it in!
--- Cut Here ---
Monsterbishi
