Id tag translation
Id tag translation
Postby TE_71 LEVIN » Thu May 27, 2004 8:26 pm
i was looking on net coupla months ago and found a site that told ya what all the stuff on the id tags meant, didnt look too flash but it did the job, problem is i was at internt cafe and i can't find it again, anyone know what i'm talking about?
TE_71 LEVIN
Postby Adamal » Thu May 27, 2004 9:39 pm
Maybe you could elaborate on what kind of ID tags you're talking about? :)
Postby rxtoy » Thu May 27, 2004 10:35 pm
is the car in your avatar yours??? cool, didn't even think there were any KE15's in new zealand.
don't know if you've already found it but here's a site you might want to check out
http://au.geocities.com/ke1x/mycar.htm
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby bridgeport » Thu May 27, 2004 11:07 pm
i think its on nzpc site under the faq tech its come up on that forum before so do a search of the forum too
bridgeport
Postby Mr Revhead » Fri May 28, 2004 11:36 am
here:
http://ourworld.compuserve.com/homepages/stepho/newcodes.htm
if you want to know about your car give me the numbers and i can tell what spec etc it should be
Postby TE_71 LEVIN » Fri May 28, 2004 11:41 pm
Cheers that was kinda what I was looking for, very helpful.
But the one I saw also had HP ratings, torque, compression ratios, bore and stroke etc. Has anyone seen that site.
TE_71 LEVIN
Postby Lloyd » Fri May 28, 2004 11:45 pm
Postby TE_71 LEVIN » Sat May 29, 2004 12:00 am
TE_71 LEVIN
