ke25 engine conversion
Postby 70ke25 » Sun May 30, 2004 9:28 pm
hey i got a sr20 off a freind fo real cheap do you now anything i should now before i start it
70ke25
Postby bridgeport » Sun May 30, 2004 10:57 pm
hrmm u want to elaborate ? by now i asume ya mean know
heres my break down
firewall cutting
x member fabrication
fuel lines
surge tank and 2 fuel pumps
wiring diagramms fior sr20 and ke25
gearbox mounts
tunnel (?)
shifter hole movement/enlargment
big diff corona mabey
custom sump i think
seen it in a ke70 and it was a tight fit from memory the radiator was put on the opposite side of the support pannel i think
bridgeport
Postby Rob » Mon May 31, 2004 7:32 am
And most important of all, a large pool of water to drown yourself in for even thinking about doing that.
Why not a rotor or v8(lexus)??????????
1990 ST185H - project
1996 VS Acclaim wagon
Rob
