SUPERCHARGERS & INTERCOOLERS
Postby FLAWLES » Thu Jun 03, 2004 6:34 pm
i think this q has been asked before but i will ask it again
will u get a craap load of lag when running a front mount intercooler on a 4ag-ze " with s/c "
keeping in mind im running a 10psi pulley
as i reckon u will
between planting ur foot ingaging the s/c clutch boost flying around to the i/cooler and then back to the engine
there would be a gap between running n/a then waam forced induction
what do u think?????
FLAWLES
Re: SUPERCHARGERS & INTERCOOLERS
Postby Monsterbishi » Thu Jun 03, 2004 7:18 pm
FLAWLES wrote:i think this q has been asked before but i will ask it again will u get a craap load of lag when running a front mount intercooler on a 4ag-ze " with s/c " keeping in mind im running a 10psi pulley
as i reckon u will between planting ur foot ingaging the s/c clutch boost flying around to the i/cooler and then back to the engine
there would be a gap between running n/a then wham forced induction
With a supercharger, there will be no measurable lag, at least with any half decent piping setup.
Worst thing for lag in any forced induction setup is a oversized intercooler, a large intercooler will have more volume than the entire piping and intake manifold put together - and then some.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby 1598cc » Thu Jun 03, 2004 10:55 pm
I have a mate whos got a spec cooler on his gtz. For running only 6psi, it goes damn quick. Also has extractors, and exhust
But what do i know... i drive a hoonda 8O which is slightly quicker than his..
Will he get good gains upgrading to a bigger pulley kit? Anyone suggest a size?
1598cc
Postby event2 » Thu Jun 03, 2004 11:35 pm
whats the standard psi pully that 4agzes come out factory with?
event2
Postby EVLGTZ » Thu Jun 03, 2004 11:45 pm
1598cc wrote:I have a mate whos got a spec cooler on his gtz. For running only 6psi, it goes damn quick. Also has extractors, and exhust
why only 6psi? is he getting some pressure drop with that cooler setup?
or just a pies supercharger?
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Bazda » Thu Jun 03, 2004 11:56 pm
180mm with the first gen supercharger (13psi)
175mm with the second (13psi)
Postby matt dunn » Fri Jun 04, 2004 12:17 am
as i reckon u will
What i have found i kinda like lag when the throttle is closed.
Because the intercooler and pipes are after the throttle plate when you take you foot off the gas it takes a few sec's to suck all the air out before the car slows.
Postby BBBrad » Fri Jun 04, 2004 8:10 am
Back in the day when I was messing around with sc setups and big coolers etc I found the following. A big cooler and longish pipe work would give, not so much lag(when u wanted the power down), but poorer/slow throttle responce, (like it would hesitate b4 it would to do, what u wanted it to do) if u can understand that. Also on sc setups it seems the bigger or more eff the cooler is the less boost pressure u will have. My understanding of this is that the sc is passing a certain amount of air (nothing can cahnge this) and when it goes through the cooler the air is becoming more denser, taking up less space and therefore boost pressure is down. I did have some numbers to back this up but they r long gone.
My new car...99 mr-s
BBBrad
Postby 1598cc » Fri Jun 04, 2004 8:37 am
Yeh its only running 6-7 psi. I thought standard was higher than that also.
Only thing is that ive found, is they dont have the top end pull.. Instead good torque from 3000- 5500.. The top end is shit actually.
1598cc
Postby EVLGTZ » Fri Jun 04, 2004 8:45 am
1598cc wrote:Only thing is that ive found, is they dont have the top end pull.. Instead good torque from 3000- 5500.. The top end is sh*t actually.
yep, thats the thing with those std s/c setups on the 4agze
EVLGTZ
EVLGTZ
Postby Lanius » Fri Jun 04, 2004 9:15 am
Why not just front mount the existing intercooler? Piping might look a bit odd being made the fit the entry and exits to the intercooler, but the main problem with the factory intercooler is that it gets heat soaked on top of the head.
Front mount it, and problem disappears. Minimal lag from new piping, don't have to buy a new intercooler, and don't have to paint it black if you're going for the sleeper look :wink:
Lanius
Postby Bazda » Fri Jun 04, 2004 11:00 am
i heard that the ideal intercooler would be one off a turbo mr2, thats just from www.club4ag.com
Postby MrBob » Fri Jun 04, 2004 11:20 am
Bazda wrote:i heard that the ideal intercooler would be one off a turbo mr2, thats just from www.club4ag.com
....which I will sell you for $200 :mrgreen:
MrBob
Postby FLAWLES » Sat Jun 05, 2004 10:39 am
sorry
thats what i was expecting poor throttle respones
so basicly what bbrad is saying if i have a big i/c and try and keep the i/c piping to a minimime i should be ok and say wot i would lose about 1 to 2 psi but gain power in the long run
sound right??
FLAWLES
Postby AE85.6 » Sat Jun 05, 2004 12:38 pm
how big is a standard turbo mr2 i/c ??? i heard vr4 ones were supposed to be the shiz niz size for them but anything bigger would be a waste or have very minimal gain ?
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby Al » Sat Jun 05, 2004 11:15 pm
MR2 i/c is a gloryfied oil cooler.
Hehe i didnt think you could give them away let alone charge $200 for them :lol:
Al
