mixing anti-freezing coolants
Postby 2fas4u » Fri Jun 04, 2004 10:41 pm
hey everyone, i was just curious, is it ok to mix anti freeze coolant together, because the ones toyota service centre puts in is orange and the ones i got from repco is green. cheers.
2fas4u
Postby Ae92typeX » Fri Jun 04, 2004 10:55 pm
Technically your not meant to. When I worked at the mechanics we did it all the time no prob.
Ae92typeX
Postby FLAWLES » Sat Jun 05, 2004 10:48 am
mixing diff ati-freeze can have diff effects
i can goe on and on but the main one u WANT TO WATCH OUT FOR IS ELECTORLILIS very very bad
buy buy engine if this happens
FLAWLES
Postby Mr Revhead » Sat Jun 05, 2004 12:18 pm
you should be able to buy the toyota stuff over the counter.... you may have to take your own container in as it gets delivered in 205 litre drums.
Postby 2fas4u » Sat Jun 05, 2004 8:20 pm
FLAWLES wrote:mixing diff ati-freeze can have diff effects
hope the ones they sell at repco aren't ELECTORLILIS. it's it comes in a red container.
2fas4u
antifreeze
Postby JasonZE » Sat Jun 05, 2004 10:42 pm
I certainly wouldnt loose any sleep about mixing anti freeze however if you are going to add some its a good idea to drain the system and get rid of the old coolant and start again with fresh antifreeze/water.
But if you just want to avoid freezing as its winter drain out a litre and add a litre of a/f
And electrolosis isnt something you add its just a reaction between the metals in your engine which eats away at water jackets and the galleries/fitting etc causing headgasket failure usually.
Antifreeze also has anti corrosion which prevents this happening making the anti corrsion properties more important in my opinion than the antifreezing side of things unless you cruise antartica on a regular basis. :roll:
JasonZE
Real Life Mechanic
Re: antifreeze
Postby 2fas4u » Sat Jun 05, 2004 11:49 pm
JasonZE wrote:... unless you cruise antartica on a regular basis. :roll:
:lol: :lol: :lol: cheers.
2fas4u
