Ep82 4fte 2 4gate?
Ep82 4fte 2 4gate?
Postby Linz » Thu Jun 10, 2004 3:01 am
i wana put a 20v turbo into my ep82 starlet has it eva been done before?
does any1 have any advice on wot 2 do or wot parts ill need or any otha sugestions wod b good? :?
Linz
Postby Shady_Dan » Thu Jun 10, 2004 3:13 am
yeah, the 20v's do fit quite nicely, but being a different engine, it will need custom mounts made up, and ull need all the hardware from the engine (wiring loom, computer (if your running a 20v turbo ull need an a/m computer anyway), and if u can the actual 20v mounts so u can mould them to fit the engine bay).
Grab the 20v levin brakes as well as i dont think the ep series discs are up to the task.
Also take into account that all this will need certification, as ur running an engine thats more than a 20% increase in cc rating than the original. (think thats how it goes, but ull need a cert regardless).
If your ep starlet is a non turbo, why not source the GT starlet turbo motor? not bad for what they are and can get decent power ratings out of them with a bit of work, might be a more viable option.
Also, u may need to upgrade the gearbox to a 20v one as well, dont know how much work thats gonna be to fit, as i dont know if the bellhousings and mounts would be different or not. Using the ep gearbox could be done, but i think ur ratios would be all wrong for the engine.
hope this helps...
Shady_Dan - Keeping skanks in check since 1999
"Whats the difference between God and the Mt Maunganui police?"
"God doesnt think he's the Mt Maunganui Police"
Shady_Dan
Postby Twolitre » Thu Jun 10, 2004 12:53 pm
A 4AGTE would give a nice increase in torque in a little starlet but have you considered modifying the original 4EFTE? I personally beleive that are very under-rated engines. Would be alot cheaper too.
Twolitre
Postby diss7 » Thu Jun 10, 2004 2:16 pm
Shady_Dan wrote:yeah, the 20v's do fit quite nicely, ...
No they dont. Go get a ruler and you'll see that the chassis rails are too close to fit any 4age engine. Expensive conversion, for half the money you could have your 4efte spinning up 3rd gear and doing 13s
diss7
Postby AceSniper » Thu Jun 10, 2004 5:27 pm
gt starlet uses the same g-box as the 20v (c56 with lsd)
AceSniper
Postby Stu- » Thu Jun 10, 2004 9:17 pm
GT Starlet Gearbox = c52-522 (Non LSD) or c52-523 (LSD)
Project Thread
Stu-
Postby Linz » Fri Jun 11, 2004 3:47 am
cheers guys the reason i ask is if u can remember back nzpc mag featured 2 ep82 starlets 1 wif a 4agze and the otha wif a 4e-fte mine has a 4e-fte motor and a c52-522 trans i want a c52523 trans but i cnt find 1 any help there?
ive just been told lots of horror stories about modding a 4e-fte motor thats why im looking around at otha opions any1 wif advice on how 2 do a 4e-fte right wod b awsum cheers :)
Linz
Postby krad » Fri Jun 11, 2004 9:14 am
www.starletcentral.co.nz
starlet.bodykit.co.nz
autos.groups.yahoo.com/group/gtstarlet/
Check out these sites for info etc. I don't think moding a 4EFTE is hard? Just add bolt-ons pretty much :). Depends how much you want out of them.
I've heard of people running 25psi on port and polished internals + decompression gasket, uprated fuel, T3 turbs, no forgies etc etc.
krad
Postby Rollux » Fri Jun 11, 2004 2:36 pm
4EFTE is a bloody strong wee motor, just make sure you give it enough go go juice, they tend to run a bit lean when you bolt big turbos on and run a bit of boost.
As for the box with a factory LSD, rarer than rocking horse sh*t, I looked for months when I had mine. I suggest you buy a TRD/Quaife unit, as they are a clutch type, not a viscous unit.
Another thing you can do with the 4E, grab a 5E bottom end, put your 4E pistons in, bolt on the 4E head and a bigger turbo, and you've got a 1500 that kick arse and still looks like the 1300. Don't forget the fuel pump & injectors!
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby krad » Fri Jun 11, 2004 4:05 pm
Whats wrong with a TRD viscous unit LSD?
I thought were the better choice?
krad
Postby QikStarlie » Fri Jun 11, 2004 7:57 pm
http://forums.starletcentral.co.nz/viewtopic.php?t=511
sift thru the spam on that post.. should help you a bit
the people telling you the horror stories, are probably also the ones who wind the boost up and dont add extra fueling. then complain coz they are weak motors when the ring lands crack a few days later...
ive only cracked 1 set of ring lands (because of dodgy head gasket) in over 20'ks running 16psi on a t25(dead) & 18psi on a t3
oh and i run the trd helical lsd, works mint
QikStarlie
Postby Rollux » Mon Jun 14, 2004 1:52 pm
krad wrote:Whats wrong with a TRD viscous unit LSD?
Well, on a RWD at least, they don't work any where near as well. Eg, the viscous LSD transfers about 20% of power to the wheel with the most traction, whereas a clutch type, depending on setup, will transfer about 40%. The downside is a clutch type wears out, whereas a viscous is sealed and works similar to a viscous fan and is almost maintenance free. A clutch setup will get a close to 50/50 distribution in a straight line, so better for drags, but means more power understeer on corners.
But hey, a viscous is still better than open!!
Rollux
Postby Linz » Fri Jun 18, 2004 3:51 am
mint where do you get a trd lsd from?
im stickin wif the 4e-fte motor i just got a s5 rx-7 ic which im gonna use 4 a f/m and im high flowing the std turbo and c wot happens any1 got any ideas of wot i shod do afta that? :D
Linz
Postby AXNGRL » Fri Jun 18, 2004 10:06 am
depends on how much power you want & what you want to use the car for, ie, drags at Meremere or round the track at Manfield.... Before you increase the boost, you will need to consider more fuel, a GTX or a MR2 turbo fuel pump will do the trick without having to go to upscale... relocate your air filter so that it comes directly off your turbo, then you've finished sorting out your incoming air. Then its up to you... suspension, more boost = bigger turbo, different manifold (standard ones are very weak on a starlet) I take it you have done the exhaust already?
AXNGRL
