how do you know if your wheel bearings shot?
Postby fatgtr » Thu Jun 10, 2004 8:47 am
how do you know if your wheel bearings shot? ie does it make a particular noise? my car either has dead cv joints or wasted wheel bearings. im pretty sure its the cvs. but any help would be great :D
James
gotta love the punk music
fatgtr
wheel bearings
Postby THA SHZ » Thu Jun 10, 2004 10:59 am
Hey man , the easiest way to check if its ur wheel bearing is if you jack up the front wheels and put one hand at the top of the wheel and one at the bottom and try and rock it backwards and forwards if you have play that you can feel than your bearings are shot .
As by noise a cv will make a clicking noise when going round a corner a bearing will make a deep whurring sort of noise which gets louder when you go round a corner :D Hope this helps.
THA SHZ
Postby Rollux » Thu Jun 10, 2004 3:04 pm
Otherwise, the easy way is take your car to the testing station and ask if your wheel bearings are shot. They'll check em 4 free, and be honest.
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby Snoozin » Thu Jun 10, 2004 4:02 pm
To see if it's your CVs, find a cul-de-sac, and turn full lock in one direction, applying mild throttle, and listen for clicks. Do the same in the other direction. Then you have an indication of which might be worn as well.
Snoozin
Postby fatgtr » Thu Jun 10, 2004 5:55 pm
hey guys thanx for your help. i did the couldersack trick and both my cvs are gone im assuming its the outer 2.
James
fatgtr
