Programming a Apexi electronic boost controller
Postby footaction29 » Sun Jun 13, 2004 3:12 pm
I recently bought a pulsar gtir with the apexi boost controller in it,the problem is the boost is set to 20psi and it came with out any instructions.Is there anyone out there that can post step by step the way how I can lower the boost on this controller as soon as possible.
footaction29
Postby turbo tezza » Tue Jun 15, 2004 9:02 pm
Is the boost controller running off a power fc computer?? Or is it a standalone boost controller??
If its running off a computer, you will probably need a hand controller to re-programme the boost settings. A tuning shop should be able to re-tune it for you, or point you in the rite direction, or maybe somebody here mite have 1 you can borrow.
Just a thought.
I'm getting a power fc + hand controller in early July. I'm in chch tho. Where r u?
turbo tezza
Postby fivebob » Tue Jun 15, 2004 9:14 pm
Postby footaction29 » Thu Jun 17, 2004 3:31 pm
Yes I found the apexi web site,found the entire manual to download.
footaction29
