3sgte - rwd convo - anybody no of any gbox that wil bolt up?
Postby dattohoe » Mon Jun 14, 2004 10:02 pm
yeah as the topic ses 3sgte going into a ke25sr coupe, have t50 gear box is there any bell housing that will bolt onto that that may bolt upto the 3sgte? or is there any other rwd box that will bolt up?
i hear of a mythical rwd 2c dizezal w55 box will bolt up but how rare would that be? and what does it come out of? a liteace truck or somthing?
someone must have some info on this, share and share alike i say.
peace
cheers to anyone that helps me out
mike
dattohoe
Postby badidas » Mon Jun 14, 2004 10:05 pm
i dont think a t50 would last long being pushed by a 3sgte !!!!
you need a w5* with a bellhousing adapter made up
1989 mazda bongo aka [BNGBUS]
badidas
Postby Al » Mon Jun 14, 2004 10:11 pm
Theres a S to W5* bellhousing for sale in parts
t50 would break damn quick with the torque of a 3s
Al
Postby NZ_AE86 » Mon Jun 14, 2004 10:47 pm
They are more common then people think! The w55 and w57 box both appear behind little 1S - 3S engines! Go to a good toyota wrecker and you should get one. I see then here in welly when I am poking around at wreckers. Yeah and a T50 would only last so long.
NZ_AE86
Postby KinLoud » Mon Jun 14, 2004 11:32 pm
I have got several s motor to w gearbox bellhousings.
I have bellhousings with the starter on the left.
Also some bellhousings with starter on the right which is better for the 3sgte as the turbo can get in the way of the starter (will need one hole to be slotted).
$150 each.
I will include the metal plates that go between block and bellhousing, clutch release arm, the metal braces that go between the block and the bellhousing and I should be able to find clutch slave cylinder but probably best that you buy a new one for about $30.
Are you in the wellington area? If so I can drop it off at the airport.
Ken
Taupo
021 408 863
