Radiator fan prob on FXGT
Postby SIDE_FX » Tue Jun 15, 2004 7:56 pm
hey i have a nz new gt nd the radiator fan works some times but not others i mean like when its over heating or sittin in traffic it may or may not work how can i fix this is it my thermostat
SIDE_FX
fan
Postby JasonZE » Tue Jun 15, 2004 8:23 pm
You need to test or eplace the fan switch which is normally located either in the bottom of radiator or on the water fitting on the end of the cylinder head buy not sure which on your model.
If the switch tests ok then look for a fault at the fan relay.
JasonZE
Real Life Mechanic
Users browsing this forum: Google [Bot] and 3 guests
