Injected 4age conversion
Postby Volatile » Wed Jun 16, 2004 9:45 am
Well im gathering as much information as i can before i start collecting parts for my injected 4age conversion into kp starlet.
has anyone on here actually done it themselves? if so i got some question about fuel lines etc.
What do you do about fuel lines? and surge tank? and fuel pump?
James
Volatile
Postby spencer » Wed Jun 16, 2004 10:16 am
Hey fuel lines is easy you can by the bundy tude stuff for cheap in a big roll and bend it yourself, or take your existing line into a brake and clutch place etc and they will bend it up for like $20. What I use at the moment is orginal pump into surge tank then into high pressure pump. If you did a search someone has put up a diagram on how to set this up remeber seeing a couple of months ago
ms63 crown
spencer
Postby badidas » Wed Jun 16, 2004 2:01 pm
www.club-k.co.nz check that out im sure one of those dudes could talk you through step by step
1989 mazda bongo aka [BNGBUS]
badidas
Postby rxtoy » Wed Jun 16, 2004 4:20 pm
viewtopic.php?t=16317&highlight=
check this for a fuelling setup, pretty easy. i don't think you're meant to use your stock fuel lines, they're not made to operate to the pressure that you'll be running for a fuel injected car. for my celica i'm planning on running an intank 13B turbo fuel pump (i've got a custom stainless drop tank so it won't be too hard to set up) and just using flexible line for the whole length of the vehicle, i'll probably just cable tie it to the old fuel lines.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
