vvega wrote:have you tried filling it with oil and running it ???
note fill means topping it up not till it comes out the filler
v
EVLGTZ wrote:check the waterpump, rattle may be coming from there.
matt dunn wrote:with the key on and the engine off does the oil light work?
skoty wrote:BTW, if I have rooted a bottom end crank bearing, would the motor run as good as it does still? Most people believe thats what has happened but it just seems a bit weird, I thought the engine would idol irratically, struggle to turn over and have dramatically reduced performance also if that was the case?
RedMist wrote:I'd almost bet it's piston slap. Sounds very much like you have run a bearing.
Had exactly the same issue on my SW20. Ran it low on oil and a knocking sound started, filled it up and the noise only got louder as I continued to drive it. Your damaging pistons, bores and possibly head by running it, however it would be cheaper to replace the damaged engine than rebuild it!
Daniel.
Users browsing this forum: No registered users and 80 guests
