Lowering Kp starlet
Lowering Kp starlet
Postby Volatile » Tue Jun 22, 2004 10:27 am
Hey, what is the best (legal) way of lowering a kp60 2door starlet?
don't want to spend a huge amounts of $$ but anyone got any good options?
James
Volatile
Postby Virtual Genocide » Tue Jun 22, 2004 10:46 am
Ive been told that a set of Koni shocks is the best for performance and hight (if you dont want to go for that 'sacked' look).
but yeh im looking into fixin that on my starlet aswel
good luck
Phil
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby Mr Revhead » Tue Jun 22, 2004 11:43 am
how much you willing to spend?
i can do lowering spring sets from around $380-400
Postby Volatile » Tue Jun 22, 2004 5:11 pm
Mr Revhead wrote:how much you willing to spend?
yip thats about what i'm wanting to spend - IF they are of legal hight and captive, what brand are they? i assume they are brand new?
how much do they lower it by ?
James
Volatile
Postby Mr Revhead » Tue Jun 22, 2004 5:20 pm
i can do TRD, cobra, dobi sport....
having said that TRD no longer list them to old!!
can do cobras for $395 delivered
quoted lowering 25-40mm quite a range but i think they are covering there arses with those numbers... say 30ish mm
Postby Volatile » Tue Jun 22, 2004 5:37 pm
oh yip, i'm looking to purchase some in about 2 weeks
are they guaranteed to be captive in standard struts and shocks?
Volatile
Postby Mr Revhead » Wed Jun 23, 2004 10:24 am
yes i think so, but ill confirm that if you wish to order
Postby wde_bdy » Wed Jun 23, 2004 9:40 pm
Be careful with the rear springs, my car had Gabriel shocks and standard springs were only JUST captive. You can use Commodore wagon rear shocks I think, around 50mm shorter from memory.
Callum
wde_bdy
Postby badidas » Wed Jun 23, 2004 10:11 pm
hey dude i had dobisons /dobisport in my kp60 and that thing handeled like it was on rails they were from a ka laser :? but they fitted sweet azz all captive sat right in the top hats ect
those combined with some 205/50/15"s and nothing could stop it
had cobras and i wouldnt buy them again
1989 mazda bongo aka [BNGBUS]
badidas
Postby MEX » Thu Jun 24, 2004 12:52 pm
in my old kp60 i had a wicked setup, but would have cost over a grand but i didnt pay for the labour, basicly i made new front struts that were designed to ride about 80mm lower than std, looked mean and handled great :D
cheack out the aviator or click on my homepage link
im about to do the same thing to my new KP60
Old Toyota's Never Die... They Just Get Phater
http://homepages.e3.net.nz/~bill-mecchia/
MEX
Postby Volatile » Thu Jun 24, 2004 1:50 pm
sweet, would you be able to go into a bit more detail about the struts "you made"
James
Volatile
Postby badidas » Thu Jun 24, 2004 2:50 pm
were they shortened ?
i had some struts shortened with a spacer and that worked wicked
badidas
Postby rxtoy » Thu Jun 24, 2004 6:49 pm
for that short you'd probably want to actually shorten the body of the strut, not just the strut insert. otherwise suspension travel gets pretty minimal. not hard to do if you can weld, or if you've got a mate who can, as long as you get them pretty close to straight or it might change your camber.
i'd say that something like this would need to be certed legally, whether you'd get picked up on it or not i couldn't say
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby MEX » Sun Jun 27, 2004 1:59 pm
damn i should have taking some pics we just did my mates ke30 ones(went back in the car yesturday) but yeah basicly what rxtoy said, i shortened the inserts 100mm(i should have only gone about 50 but one of them was slightly damaged so just choped that part right off:) ) then with the body i cut the threaded piece off the top, then cut 50mm off and welded the thread piece back on, there is also another sleave inside(it just slides out) that has to be shortend the same amount, i also put heaver oil in to give it a stiffer ride.
to be legal all the welding and machining etc has to be done by a certed engineer and then the car has to be certed because you altered the strut.
but if its done all nicely and maybe chuck some fresh new paint on the whole strut its blody hard to tell its been done, but usally your doing this because you want your car under 100mm so need cert anyway :D
hope that sorta helps a bit :D
MEX
Postby RE20 » Sun Jun 27, 2004 3:49 pm
Can someone give me a definate yes/no as to if the standard rear shocks in a starlet can be machined? I have been told they can't but a local suspension shop don't see why not, they didn't see they car though so couldn't say for sure.
Anyone done this?
In the event of nuclear catastrophe, the only survivors will be Cockroaches and Toyota K series engines...
pervert wrote:Haha, it's not low enough, it still has suspension travel!!!
RE20
Postby PumpN » Sun Jun 27, 2004 4:27 pm
under construction wrote:Can someone give me a definate yes/no as to if the standard rear shocks in a starlet can be machined? I have been told they can't but a local suspension shop don't see why not, they didn't see they car though so couldn't say for sure.
Anyone done this?
no they can't, if you really want i can come round and show you why
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby MEX » Mon Jun 28, 2004 12:22 am
yes they can be machined but only as in your can make anything you want if you reallly want, but for the cost of around $150inc GST you can buy a pair of monroe shocks(i can get you the exact part number) that do the job great, or about 130each for pedders
personly i prefered the ride i got with the monroes :D
MEX
Postby RE20 » Mon Jun 28, 2004 10:02 am
MEX wrote:yes they can be machined but only as in your can make anything you want if you reallly want, but for the cost of around $150inc GST you can buy a pair of monroe shocks(i can get you the exact part number) that do the job great, or about 130each for pedders
Yeah could you post or PM the part number for the monroe's? That'd be great thanks :)
RE20
Postby MEX » Fri Jul 02, 2004 1:20 am
the parts nummber is Monroe 15-3034 you should be able to take this down to any old monroe distributor and they will be able to sort ya out
MEX
Users browsing this forum: No registered users and 41 guests
