AE82 Fxgt oil filter - How the fsck do you get it off?
Postby liftback » Tue Jun 22, 2004 9:24 pm
How the hell do you get the oil filter off a 4age in an ae82? There's only _JUST_ enough room to get your fingers around the edge, but you cant get a good enough grip to loosen it because they are soo tight. Ive tried using one of those tools, but theres not enough room for me to lever my hand! HELP!
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
Whats all this then?
liftback
Postby MattrickMotorsport » Tue Jun 22, 2004 9:34 pm
Got a long screwdriver :twisted: :lol: :wink:
MattrickMotorsport
Postby badidas » Tue Jun 22, 2004 9:34 pm
i got myne off from under the car or if u cant be ferked stab a screw driver in it jk*
1989 mazda bongo aka [BNGBUS]
badidas
Postby liftback » Tue Jun 22, 2004 9:35 pm
Yeah I think i might have to... feck those japanese know how to pack everything in tightly!
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
liftback
Postby celica_tommo » Tue Jun 22, 2004 10:45 pm
yeah the screwdriver trick always works real well or if not destroy the sides of the filter making it an easier shape to turn
celica_tommo
Postby aesc » Wed Jun 23, 2004 12:09 am
If your facing the back of the car, reach in under the right hand side of the exhaust manifold when its cold (so you dont burn yourself) and youll get a good grip on it to undo it. Youll struggle to get a decent grip if you reaching in at the filter directly from the front.
But yeah if all else fails, use a screwdriver :twisted:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby ChaosAD » Wed Jun 23, 2004 7:47 pm
try a pair of polygrips (or multigrips or whatever you want to call them), cos if you try with a screwdriver and it doesnt work then you cant drive it anywhere (like a mechanic or whatever)
ChaosAD
Postby Rollux » Thu Jun 24, 2004 6:12 pm
ChaosAD wrote:try a pair of polygrips (or multigrips or whatever you want to call them), cos if you try with a screwdriver and it doesnt work then you cant drive it anywhere (like a mechanic or whatever)
A screwdriver ALWAYS works!!! :twisted:
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby spencer » Thu Jun 24, 2004 6:36 pm
I made a handy filter puller by drilling a hole in a cheap socket then threading a smallish loop of chainsaw chain through it. Then as you turn the socket chain bites into filter and rips it off. It was easy to make and beats those tools hands down but the screw driver is also a quick and easy method
ms63 crown
spencer
