LSD questions
LSD questions
Postby dreama » Wed Jun 23, 2004 1:56 pm
hey wanting some advise im looking at putting an LSD in my TA63 Carina GT-T (IRS) and wanted to know if a GA70 Supra Turbo LSD wud fit in (its from an auto if that makes any difference). Any help or advise wud be appreciated
dreama
Postby TRD Man » Wed Jun 23, 2004 2:25 pm
Not from our records.
The TA63 has a 7.5" diff. The turbo GA70 has a 8.0" diff.
The TA63 shares the same diff as the 86 ~ 88 GA70 with 1GGE or the 88 onward GA70 with 1GFE.
A GA70 from Aug 88 with the non turbo 1GGE has the same 8.0" diff as the turbo.
TRD Man
Postby Malcolm » Wed Jun 23, 2004 7:46 pm
The TA63 will probably have a T or F series, and the mounting points and methods for both kinds are quite different to the G series diff in the 1GGTE GA70, although I've seen a 1GGE GA70 with an F series but non LSD.
Postby dreama » Wed Jun 23, 2004 10:38 pm
kool so any recomendations on which LSD i cud put into it and which car to get it from
dreama
Postby badidas » Thu Jun 24, 2004 6:49 am
some t series were lsd as found in a ta63 celeca/supra (?)
1989 mazda bongo aka [BNGBUS]
badidas
Postby KinLoud » Thu Jun 24, 2004 10:15 pm
The 2 3tgte Celica/Carinas I know well both have LSD fitted.
Both of them are 7.5" F series diffs - code on the build plate on the firewall is:
F293 F=7.5" 29=4.1:1 ratio 3=2 pinion LSD
Look on your build plate. Where it says transmission Look for a code like F292, T282, F293, F295 (for example)
If the last number is a 3 or a 5 it is LSD (presuming that it is the original diff). If it is a 2 or a 4 it is an open diff.
It could be that the LSD has worn out and needs new clutches. This could cost you $400 or more to get new clutches plus fitting.
Ken
Taupo
021 408 863
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
