AFM disconnection
AFM disconnection
Postby Adamal » Thu Jun 24, 2004 8:01 pm
I was wondering if there is any disadvantage to disconnecting the air flow meter from an SW20??
Postby Twolitre » Thu Jun 24, 2004 8:10 pm
I thought you had an NA SW20? If so it should be MAP sensored if not your engine won't run if you disconnect it. Why would you want to anyway?
Twolitre
Postby Adamal » Thu Jun 24, 2004 8:17 pm
Yea, its N/A... Then what the hell was that thing I disconnected?? Car still runs... 8O 8O 8O
Its on the piping before the throttle sensor...
8O 8O 8O
Postby NA Drifter » Thu Jun 24, 2004 9:01 pm
must be the air temp sensor....
if u disconencted the AFM, you still can start the car, but you won't able to run or rev it... it will just die...
Keith
NA Drifter
