toyota supercharger models
Postby AE85.6 » Thu Jun 24, 2004 9:03 pm
i saw in parts for sale section a supercharger of a 2.4L previa van and it mite be slightly larger than the 1ggze one, just curious if anyone knew what model that would be i couldnt find any specs about them, just curious about displacement compared to the others and if pully kits are available for it etc, might be an idea for a project :twisted:
4agze = sc12
1ggze = sc14 (old soarer one ?)
previa van = ????
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby fraz » Fri Jun 25, 2004 10:53 pm
sc14 just newer and a weeee bit more refined
fraz
Postby AE85.6 » Sat Jun 26, 2004 11:20 am
but the sc12's from 4agzes are newer engines than the old soarers or so i thought ? but then again i dont know the production years that the 1ggze engines were produced cause those are the engines that the sc14's are from arnt they ???
AE85.6
Postby Shotgun » Sat Jun 26, 2004 12:06 pm
Soarers never been supercharged ever. 1ggze was from the sedans.
Shotgun
Postby AE85.6 » Sun Jun 27, 2004 8:02 pm
oh ye sedans like the older chasers etc or mark II's but ye was just curious about them compared to the one off the van anyone know about these ones ?
AE85.6
Postby AE85.6 » Sun Jun 27, 2004 8:04 pm
oh ye sedans like the older chasers etc or mark II's but ye was just curious about them compared to the one off the van anyone know about these ones ? just theory at this stage but possibly for adapting to a 4agze i assume it would be similar work like the sc14's eg having to change the direction that the inlet and outlet face ?
AE85.6
Postby Fred » Mon Jun 28, 2004 8:52 pm
i think the one for sale u talking about is the same one that i went to have a look at, its not bigger than an sc14 even if it was off a 12.4 litre, how do i knw this? cause on the sc unit it had sc14 ensribed on it =). sc14 come of previa and i think old school cressidas not sure, but yea i used to think they came off soarers aswell.
ive jst bought an sc14 and soon to be stuck on in place of my sc12. not sure if u can get a bigger superchaarger than a sc14.
if u want a crazy future mod, the next step is a sc20 i think off a landcruiser but dont quote me on that.
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby AE85.6 » Tue Jun 29, 2004 2:37 pm
mean sc20 :twisted: actually dont tell me that ill just get silly ideas, ye i would possibly be looking at gettin a ze engine put in place of my 4ager as soon as driveline and few other bits and peices done, and if i dont turbo the engine i have, but i havnt seen a sc12 and 14 next to each other so im not entirely sure about fitting it, as fair as i know the pipes are facing the wrong directions and if you are mounting in on a fwd its gettin pretty close to the firewall, seeing as mine is rwd hopefully i wouldnt have to many more dramas
AE85.6
Postby Fred » Tue Jun 29, 2004 8:12 pm
im pretty sure that there are no issues if stuck in a rwd, yea for fwd u have to knock back the firewall, u need to redo the pipping for the ic, and if u have a sc14 its prob a good idea to get a bigger ic as apparantly the teflon melts if u spin em too fast
Fred
Postby cr1mnl » Tue Jun 29, 2004 8:19 pm
Fred wrote:im pretty sure that there are no issues if stuck in a rwd, yea for fwd u have to knock back the firewall, u need to redo the pipping for the ic, and if u have a sc14 its prob a good idea to get a bigger ic as apparantly the teflon melts if u spin em too fast
yes can confirm teflon melts if you run 19psi thru a sc12, shafts also bend
www.ology.co.nz
cr1mnl
Postby gdsup » Wed Jun 30, 2004 12:44 am
just a note, intercoolers cool the air charge to the engine, not the teflon coated tips in your supercharger :)
gdsup
Postby AE85.6 » Wed Jun 30, 2004 2:31 pm
ye i was thinking a vr4 front mount anyways, but an sc14 still has a similar boost to an sc12 doesnt it and just flows more air? so i was thinking an sc14 with a pulley kit that would still be alot lower than 19 psi so would that make issues with bending a shaft or melting teflon ? and then i realise with all the extra piping and bigger intercooler you get the "sticking throttle" syndrome casue it has a lot more air to suck thru before it adjusts, if i keep the piping as effcient as possible and maybe just use a slightly smaller diametre pipe would this elliminate it ??? 2" pipe or something ?
AE85.6
Postby Fred » Wed Jun 30, 2004 6:43 pm
Sir-Gurew has his set up running 18psi but thats with an extra injector and gt4 fuel pump, ul have to upgrade the fuel pump no matter wat u gna run. i guess smaller piping wu shorten the adjstment time a lil but then u sacrificing the better air flow
Fred
Users browsing this forum: Majestic-12 [Bot] and 73 guests
