16v 4AGE cam spec
16v 4AGE cam spec
Postby NA Drifter » Sat Jun 26, 2004 3:15 pm
I notice for the factory Spec of the 4AGE 16v, the redtop got more power than the bluetop.
The differents from the design between these engine ..from what I can tell it,
1: Compression
2: intake port size & Tvis
3: cam lift and duration
So I wonder which is the main reason(s)for the power incress for the redtop engine..??
Redtop got more compression but smaller port and no TVIS, less lift on the cam and also sorter duration cam??
Compression and smaller port+ no tvis might give you more power but the cam lift and duration is reduced?? :? Is there any reason for that? They using the same cam profile (lift and duration)as the 4AGZE engine!
Why they don't stay with the more duration and lift cam for the redtop engine from the bluetop cos that might give you even more power??
Keith
NA Drifter
also
Postby ezy10s » Sat Jun 26, 2004 4:29 pm
the redtop runs a different ECU which could account for a kw or two.
Member #244
ezy10s
Postby NA Drifter » Sat Jun 26, 2004 4:33 pm
yeh forgot about that too..
so does it mean having bluetop cams on redtop engine incress power??
have anyone done that and have a good result? I heard of a few peoples done it but I still donno why factory didn't do it... :?
Keith
NA Drifter
Postby skoty » Sun Jun 27, 2004 4:11 pm
NA Drifter wrote:so does it mean having bluetop cams on redtop engine incress power??
Apparantly :?
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby PumpN » Sun Jun 27, 2004 4:29 pm
NA Drifter wrote:yeh forgot about that too..
spose to give a small gain uptop and a sacrifice low down but without the TVIS it has a really loppy idle, dont think granny would want an fxgt which goes brap brap brap
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby NA Drifter » Sun Jun 27, 2004 7:39 pm
ohh ic... well, is ok if you after performance then... loppy idle sounds make the car sounds like sick.. which is cool when you rev the engine up as it will give the nice roaring sounds 8)
Keith
NA Drifter
Users browsing this forum: No registered users and 79 guests
