Ae85 -> Ae86 help
Ae85 -> Ae86 help
Postby slithr » Sun Jul 04, 2004 11:35 am
Hi I have just bought an AE85 manual and after searching through the tech forum I still have a few questions.
From what I have read I can bolt a 4age straight onto my k50 gearbox, so do I use the 4age flywheel and clutch? does the k50 have the same splines on the input shaft as the t50?
If I bought an AE86 rear end would my ae85 driveshaft bolt straight onto the pinion flange on the diff?
Does any other toyota other than AE86 have bigger brakes that bolt straight on (aw11? celica?)?
Does AE86 have power steering that I could bolt on and how do you guys get on drifting with no power steering?
Thanks for any help cause I have just changed from nissans and dont know a lot about toyota model compatability
slithr
Postby Dori_85 » Sun Jul 04, 2004 12:11 pm
use 3a flywheel, 4age clutch plate, 3a pressure plate and 3a thrust bearing.
the splines between the k50 and t50 are not the same.
no the diff would not bolt up to a k50 box and driveshaft.
not sure on the brakes sorry, bolt on would pretty much only be ae86 ones, but other upgrades with little modification have been done including skylines, silvia/180sx etc
yes some ae86 came with power steering but i think its better with the rack cause it gives u a better feel for the road.
current: s14 silvia k's.
previous: ae85 levin 4agte, rt84 corona, kp61 starlet.
Dori_85
Postby NZ_AE86 » Sun Jul 04, 2004 1:59 pm
Your AE85 Driveshaft will bolt up to an AE86 diff, they have the same flange.
NZ_AE86
Postby fangsport » Sun Jul 04, 2004 2:02 pm
Dori, are you positive that the d/shaft won't work? i have a fine spline T-50(same output spline as a K-40/50) mated to an AE86 rear end and i used the AE70(same as AE85)d/shaft. if you use the coarse spline box, a corona d/shaft will fit.
fangsport
Postby PumpN » Sun Jul 04, 2004 5:59 pm
Dori_85 wrote:use 3a flywheel, 4age clutch plate, 3a pressure plate and 3a thrust bearing.
No, wrong :P
4AGE flywheel (its an 8 bolt flywheel, the 4AGE had an 8 bolt crank, 3A is 6 bolt and not capatible with a 4AGE)
You will need a 4AGE pressure plate to bolt to your flywheel
4AGE spigot bearing (get one new, from ripco/toyota/bnt)
3A clutch plate (4AGE spline does not match K50) CLUTCH MAY SLIP
You will also need to fabricate a custom 4-5mm spacer for your K50 thrust as 4AGE flywheel is thinner
You will need the backing plate off your 3A to put on the 4AGE, bolts straight up, need it for the K series box
Please, if you haven't done this before then dont give advice.
Helping ae85coupe do his conversion it was very stressfull with a lack of advice and what was available was bs from people who hadn't even done the work.
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby gdsup » Sun Jul 04, 2004 7:51 pm
hey man, ditched the s13 aye! dont use the power steering, just get a manuel rack with some tie rod end spacers, if pos try and use the power steering knuckles ( bit that bolts to the bottom of the strut ) as these give quicker turning and a bit more lock too,
gdsup
Postby fangsport » Sun Jul 04, 2004 8:16 pm
WTF are tie-rod end spacers?
fangsport
Postby gdsup » Sun Jul 04, 2004 8:51 pm
spacer that slide in between the inner tie rod and the steering rack shaft, add quite abit more lock, good for drifting and three point turns
gdsup
Postby fangsport » Sun Jul 04, 2004 8:57 pm
must work similar to the threaded section i added to my steering between the inner and outer tie rods, the only issue i have is grabbing the chassis rails on hairpins, especially with gravel (soft) set up.
fangsport
Postby slithr » Mon Jul 05, 2004 6:38 pm
PumpN- Thanks very helpful! :D
gdsup- Yeah I sold it cuse I wanted to save some $ for a house but after 2 months I have serious drift withdrawl. I wanted to see what all the AE86 hype was all about.
My old 180sx has a pic in this months performance car so its still doin the rounds!
slithr
Postby gdsup » Mon Jul 05, 2004 7:36 pm
haha, i thought i might be able to do the same thing... once its in your blood... yeah was try to work that out, i saw the pic but cant remember you being there on the day, all make sense now, need any techo tip advice on 86 dont forget about the garage dori forums too
gdsup
Postby crispy'86 » Mon Mar 13, 2006 6:18 pm
Now for the thrust bearing instead of making a 4-5mm spacer for it on the k50 can you get a thicker bearing if possible to find one to suit?? And is it the bearing itself that's pressed on to the housing that needs spacing or the housing needs spaced behind the housing?
crispy'86
Postby AE85coupe » Mon Mar 13, 2006 7:16 pm
yep me and PumpN sure did get some retarded advice from people
i don't know of any thicker thrust bearings that will fit
also i had to grind some meat out of the inside of the k50 bellhousing to fit the 4age flywheel
the gearbox lasted for a while... till i started doing burnouts/dragging people...but the clutch never slipped
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby crispy'86 » Tue Mar 14, 2006 12:12 pm
Okay thanks , i'm helping a guy out doing a 4age conversion and advising him of what to do and supplying flywheel etc for him. Every bit of advice helps though
crispy'86
Postby sergei » Tue Mar 14, 2006 12:19 pm
FYI earlier 4AGE had 6 bolt flywheels.
Postby AE85coupe » Tue Mar 14, 2006 2:32 pm
sergei wrote:FYI earlier 4AGE had 6 bolt flywheels.
only the very very first blue-top had 6 bolt flywheels, and they are extremely rare
the chances of you getting one = slim
Details of car here
AE85coupe
Postby crispy'86 » Wed Mar 15, 2006 12:23 pm
Yip extremely rare to find 6 bolt flywheel with 4age. All the ones i've dealt with have been 8 bolt type
crispy'86
