Embarassing..........
Postby PoMmY » Tue Jul 06, 2004 10:04 pm
Hey guys/gals
Im currently rebuilding a 4age 20 silvertop and am beginning to take the camshafts off, unfortunately the bolts holding them on are making me look like a right **^%^$# tard, can anyone and everyone suggest as many ideas as possible to get a bolt off, and dont say turn it!lol
Cheerz everyone :D
P.S Or is there somethin else that needs to come off in order to take the bolts out???? :oops:
PoMmY
Postby Chickenman » Tue Jul 06, 2004 10:32 pm
Assuming there's nothing else that has to be done before removing the bolts.
Get sum1 to hold a real good quality socket(on a ratchet) on the bolt, get a big $&#$% hollow bar :twisted: , put it on the end of the ratchet and turn. You'll either get it undone, break the ratchet or socket or even snap the bolt. I've broken heaps of ratchets doing this so make sure you use a good quality one (ie: not Supacheap :lol: )
Baby Jesus
Chickenman
I Am The Walrus!
Postby Ae92typeX » Tue Jul 06, 2004 11:17 pm
just get a powerbar insted of a rachet, there heaps stronger. Put a pipe on that & you should be sweet.
Ae92typeX
Postby matt dunn » Tue Jul 06, 2004 11:27 pm
Ae92typeX wrote:just get a powerbar insted of a rachet, there heaps stronger. Put a pipe on that & you should be sweet.
And use a 6 point socket not a 12 pt.
Postby Chickenman » Wed Jul 07, 2004 1:50 pm
Powerbar *doh!* I've had cheapass socket sets for way too long :oops:
It's ok, I'm mechanically spastic :D
Baby Jesus
Chickenman
I Am The Walrus!
Postby PoMmY » Wed Jul 07, 2004 2:16 pm
Lmao chickenman.
Cheerz guys, ill give it a go this afternoon. Wanna really get going on this 4age aye :D
PoMmY
Postby Mr Revhead » Wed Jul 07, 2004 2:21 pm
have you tried some wd40 or something?
i pulled the cams out of a redtop last night.... they arent very tight... but i am a tuff bugger :wink:
btw, you got a good source of parts for it? gaskets water pump TRD bearings etc etc can do amazing deals pm or email me if i can help
Postby overkill » Wed Jul 07, 2004 6:14 pm
yea he used CRC stuff, i thought they all should be at the same tightness tho?
overkill
Postby Crimson Tears » Wed Jul 07, 2004 10:45 pm
You will most definitely need a decent power bar. Even if you have a decent ratchet, why would you use it on a tight bolt? They aren't made for undoing super tight bolts, that's what your power bar is for. If the ratchet doesn't break, you will certainly be doing damage to the ratchet mechanism.
I hope you also realise that there is a special procedure for removing the camshafts from the cylinder head. You should remove the cap bolts in a sequence, like the head bolts. The service manual provides a spec as to what position in degrees the camshaft should be in when the camshaft is to be removed (in terms of valves open and closed etc). You want the camshaft(s) to lift up evenly, otherwise you can quite easily damage the thrust faces of the camshaft and your thrust clearance will be all up the wop in which case it will either be noisey or could seize.
I strongly suggest you consult the service manual for the correct procedure for disassembly.
Cheers,
Mike.
Crimson Tears
Postby Chickenman » Thu Jul 08, 2004 12:14 am
The only powerbar I've got is made of muesli :D
Baby Jesus
Chickenman
I Am The Walrus!
Postby Inane » Thu Jul 08, 2004 10:42 am
there is another trick,
use a welding torch or similar, and heat the surrounding metal (so it expands) apparently it then becomes much easier to take off)
My mates used this trick all the time, I've never tried it myself,
so all care no responsibility.
Inane
Postby PoMmY » Thu Jul 08, 2004 8:06 pm
Few alright ideas there, and im guessing these power bars can be picked up from a local hardware store? Repco?
Ok new question, if a bolt is rounded to the state that wrenches and spanners dont work :oops: What to use then?
hehe, my bad :D
PoMmY
Postby cr1mnl » Thu Jul 08, 2004 8:15 pm
a 6 point impact socket. if that cant get it you have to cut it off, drill it and use a stud remover like ezy-out or something or else try get vise-grips on it. also when purchasing a powerbar make sure you get one with a warranty.
www.ology.co.nz
cr1mnl
Postby PoMmY » Thu Jul 08, 2004 8:57 pm
Ok cheerz, il see what i can find.
O and thanks Crimson, i had little idea of this and was about to ask a few people, i dont have the manual but have a 4age rebuild manual so surely that will have it. Because im replacing them with other TRD items, will they need to be put in professionally, or can i do this with a bit of reading and advice?
PoMmY
Postby Mr Revhead » Fri Jul 09, 2004 11:05 am
um what TRD items? i hope you dont mean the bolts cause if some ones sold you TRD headbolts youv been duped....
same with cams, TRD no longer do them for the 20v.....
Postby PoMmY » Sat Jul 10, 2004 2:10 am
lol no dont worry, i talked to you bout this not long ago, i perhaps included irrelevant info. I am looking at putting certain TRD items in this engine, but not cams.
And dont worry, ill contact you when i have the money. Ive heard you are pretty good with deals. :D
PoMmY
Postby Mr Revhead » Sat Jul 10, 2004 12:32 pm
i forget. too much vodka :D
thats all cool then, wasnt worried about who you buy it off... more that some ones gunna con you.
theres been a few 'TRD' parts sold that arnt TRD, then when they dont perform as such pl think TRD arnt as good as they are. thats my main concern!
Postby TRD Man » Sat Jul 10, 2004 2:03 pm
Not from here there haven't. So I hope you're not trying to discredit anybody unfairly, Warwick.
It is certainly important to deal with the agents. I do agree.
Not only for the best price, but the best advice as well.
TRD Man
Postby Chickenman » Sat Jul 10, 2004 4:06 pm
I din't think he implied that at all dude, you need to chill. :?
Baby Jesus
Chickenman
I Am The Walrus!
Postby PoMmY » Sat Jul 10, 2004 6:37 pm
Argue in my thread, and ill fuken scream! lol :D
PoMmY
Users browsing this forum: Bing [Bot] and 60 guests
