rallymazda wrote:car: AE111 with racepro seats
wat i want to know does anyone have any idea on how to install a 4 point harness in a car that dosnt have a roll cage, it also has the rear seat at the moment
i presume the 2 side belts would be attached to the factory belt mounts but where can i mount the 2 belts that go over the shoulders???
NZ_AE86 wrote:Hope you also know that it is not legal to drive the car on a public road while wearing the harness, you will need to wear your factory seatbelt when not on the track.
NZ_AE86 wrote:That is the ticket! But you won't get one unless the harness is mounted to a cage or similar structure! Best to go the whole hog and put a cage, seats and harness's in!!
NZ_AE86 wrote:yep, thats all good but you need to have the mounts to mount the shoulder harness straps, as there is no rear seat then there is no rear seatbelt mounts!
Leon wrote:OE mounts are "okay" assuming the angles as mentioned above are met. But definitely not recomended.
nemesis wrote: How is this done given there would be no OE mounts directly behind the seat?
Jools wrote:I thought the only thing the LTSA had against them, was that in an accident it was harder to get occupants out with the normal latch?
Jools wrote:Acctually i was under the impression that 4 point harnesses were leagal for street use as long as they used the quick release twist latch, rather than the more common lock latch?
