4AGE Distributor Leaking
Postby simongnz » Fri Jul 09, 2004 3:35 pm
Hi,
I've got an old AE82 and the distributor leaks oil from the inside, does anyone know how to fix this or where I can get a replacement at the right price?
I have already replaced the o-ring seal on the distributor shaft. The oil is coming out under the distributor cap.
simongnz
Postby Snoop » Fri Jul 09, 2004 7:12 pm
righto, replace ALL the seals and try it, if it still leaks get a 2nd hand dizzy and swap the shaft (your shafts probably gouged) you can try machining the shaft down a bit but thats not really a perminant fix.
As for a replacement, keep an eye on trademe and here on toyspeed for anyone selling engines or engine parts and just try asking them to sell seperatly, i got one for $20 :D
oh yea, theres 2 seals along the shaft i think, I did the same as you and replaced one and found that it still leaked a bit, AND replace the bearing with a new one, it'll be pretty worn by now after having all the oil washing thorugh it.
A plan so good my head would explode if I even began to know what I was talking about...
Snoop
Re: 4AGE Distributor Leaking
Postby matt dunn » Sat Jul 10, 2004 1:44 am
simongnz wrote:Hi,
I have a second hand dist and can do a deal on price.
PM me for details.
Matt
Users browsing this forum: Bing [Bot] and 21 guests
