My 94 MR2 G-Limited temperature gauge is starting to rise!
Postby the jetnz » Mon Jul 12, 2004 7:33 am
Help!!! I've just noticed this happening, it hasn't hit the RED yet.....
I'm not very mechanically minded so any help will be greatly appreciated.
So should I first look at the radiator???
the jetnz
Postby Adamal » Mon Jul 12, 2004 8:47 am
Make sure that you've got enough water and coolant in the system. By the sounds of things, you could do with a bit more water in there. Failing that, your thermostat could be buggered.
Postby Monsterbishi » Mon Jul 12, 2004 9:39 am
Adamal wrote:Make sure that you've got enough water and coolant in the system. By the sounds of things, you could do with a bit more water in there. Failing that, your thermostat could be buggered.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
