Camera in cars --- previously -> Drilling and roll cages?
Postby Stealer Of Souls » Wed Jul 14, 2004 7:32 pm
Hey there... I'm wanting to build a mounting setup for a camera in my car... What I wanna know is can I drill into the roll cage? Or is that illegal?
Last edited by Stealer Of Souls on Thu Jul 22, 2004 12:24 pm, edited 2 times in total.
'86 AE85.5 Levin
Stealer Of Souls
Postby fangsport » Wed Jul 14, 2004 8:09 pm
i would be far wiser to clamp/weld a bracket to the cage for this purpose.
fangsport
Postby GT4 20 » Wed Jul 14, 2004 9:40 pm
Whether it's illegal or not, I'd advise against it as driiling a hole will potentially weaken that tube.
Far better as fangsport says to clamp a bracket on. I'm pretty sure that any bracket must conform to a minimum load rating too.
Gary
GT4 20
Postby Leon » Wed Jul 14, 2004 11:57 pm
weld or make a bracket.
Has to be good for 20 g's off the top of my head.
Postby NZ_AE86 » Thu Jul 15, 2004 8:39 am
Yeah, clamp something to the cage but to keep all scrutineers happy you need to semi enclose the camera. But do not weld to your cageor drill into it as this will void your Homolgation (I asume it is homologated).
NZ_AE86
camera
Postby JasonZE » Thu Jul 15, 2004 9:14 pm
You need to make up a mounting system for the camera it pays to have a flat area so the bolt going into the camera clamps the entire bottom of the camera to the monting platform rather than having it hanging off that single bolt alone.
Steel "U shaped" exhaust clamps are cheap and plenty strong enough and can get them anywhere repco pitstop etc.
Just put some thought into it as you do need a bit of adjustment to get the camera angle right and most cars i have seen the cam is on the diagonal cross bar as well.
JasonZE
Real Life Mechanic
Postby Stealer Of Souls » Fri Jul 16, 2004 12:02 am
hey all...
My cage is supposed to be homologated... But I never did find out what happened to my paperwork... it's on the list of things to do....
I was leaning toward bolting the bracket/platform/whatever to the cage using those U clamp thingys....
If I ever get off my lazy butt I guess I'll figure it out properly...
'86 AE85.5 Levin
Stealer Of Souls
Postby Si » Sun Jul 18, 2004 4:07 pm
Where is it you want the camera pointed?
Si
Postby Stealer Of Souls » Sun Jul 18, 2004 11:51 pm
The one I'm wanting to attach to the cage will point forwards.
The rear facing one will be mounted on the hatch somewhere...
'86 AE85.5 Levin
Stealer Of Souls
Postby t0ms » Mon Jul 19, 2004 12:58 am
as some one has already stated, welding or drilling into the cage will void the homologation as it could possibly cause a weak point. much better to make up a bracket or the like to mount it onto.
might wanna take into account the size of the camera also assuming that your needing a "plate to mount it on" it aint small...
personally i wouldnt like the through of a couple of kilo's worth of camera bouncing round inside the cabin in the unlikely event.
would it not be wise to invest in something like a small colour tube camera or something such that usually come with a swing mounting that you could modify to clamp onto the pipe of the cage???
my 2 c anyway
tom
t0ms
Postby Stealer Of Souls » Mon Jul 19, 2004 12:49 pm
I was thinking of using my digital camera for now, but ultimately I want to use colour CCDs... they're so small it wouldn't matter...
I want to use a plate to provide a stable platform I can build shock asborbing in to...
'86 AE85.5 Levin
Stealer Of Souls
Postby MrOizo » Mon Jul 19, 2004 2:01 pm
OR
i can hook you up with a camera setup...
if you get a copy of the TS DVD you can have a look at some of the work ;)
We use a suction cup tho, but if you were keen and wanted to contributee a little we could always get a clamp...
At the moment were recording to Mini DV but hope to be going straight to MPEG in the future...
As long as you have a place to tie down the recorders bag we can do somethign about it. :)
Let me know - should be able to sort you out...
PM for more info :)
MrOizo
Toyspeed Legend
Postby Stealer Of Souls » Thu Jul 22, 2004 12:23 pm
Looks like a good idea...
How permanent do you reckon you get these? What are they worth?
I'm thinking of using the cameras as a security thing as well... When not on the track a laptop or VCR could record what the cameras see when I'm not in the car.
I'm also thinking of mounting cameras to watch my pedals and dash so that I can see what I'm doing when I'm driving to try and improve my technique etc....
'86 AE85.5 Levin
Stealer Of Souls
