Fuel pump wiring
Fuel pump wiring
Postby Stealer Of Souls » Wed Jul 14, 2004 7:41 pm
Okay... this may seem stupid... but...
The two wires are power and ground? I'd hate to start making mods and finding out I'm wrong... also... does the ground go straight to ground? Or through somewhere/something else first?
'86 AE85.5 Levin
Stealer Of Souls
Postby spencer » Wed Jul 14, 2004 7:50 pm
yea the two wires are power and ground and the earth should probly be grounded some where on the car
ms63 crown
spencer
Re: Fuel pump wiring
Postby matt dunn » Fri Jul 16, 2004 1:16 am
Stealer Of Souls wrote:Okay... this may seem stupid... but...
Depends on the car.
What sort of car?
Postby Stealer Of Souls » Fri Jul 16, 2004 12:27 pm
AE85 with a blue top 4A-GE in it... I didn't do the engine myself...
'86 AE85.5 Levin
Stealer Of Souls
Postby MrOizo » Fri Jul 16, 2004 2:02 pm
some require some sort of a signal through the ECU, or a fuel ECU...
I know the guys in the US have trouble in the JZA80 (MKIV's) when wiring up dual Walbros or any 2 pumps for that matter, and need to run one of them on the stock wiring and the other on a relay...
i guess the AE8*'s wouldnt have that affected would it? :o
MrOizo
Toyspeed Legend
Postby matt dunn » Sat Jul 17, 2004 9:03 pm
Stealer Of Souls wrote:AE85 with a blue top 4A-GE in it... I didn't do the engine myself...
Then yes the earth is straight to ground. Power comes from a fuel pump relay controlled from the ECU.
Postby Stealer Of Souls » Sun Jul 18, 2004 11:51 pm
cooo....
Cheers...
'86 AE85.5 Levin
Stealer Of Souls
