Bluetop Idle
Bluetop Idle
Postby ee904age » Tue Jul 20, 2004 6:05 pm
My bluetop is idling at approx 2500rpm! I have all vacuum hoses blocked,(except FPR, MAP sensor and TVIS).
Blocking off the bypass hole in the throotle body helps sometimes but still only brings it down to 1500rpm.
I have noticed no pattern with temp/idle as it does it when hot and cold.
The idle screw is wound completely shut and timing is at 10 deg btdc.
Any help appreciated.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby 4agepwr » Tue Jul 20, 2004 6:15 pm
is this only when its cold?
coz they idle at around 2000rpm when they are cold and then drop off to just under 1000rpm
otherwise it could be your throttle position sensor(tps) needing to be replaced.
Jappa AE82 Corolla GT Sedan
EX: AE82 NZ New Corolla GT Liftback
4agepwr
Re: Bluetop Idle
Postby Lloyd » Tue Jul 20, 2004 6:29 pm
ee904age wrote:I have noticed no pattern with temp/idle as it does it when hot and cold.
:roll:
Anyways... my GTZ was idling high as a while ago. Turns out I just needed to turn the AIC (Air Idle Control? or whatever its called) around a bit.
Postby RedMist » Tue Jul 20, 2004 6:49 pm
What about the rocker cover breathers? Or even the oil cap.
IAC could be an issue, possibly even a coolant sensor short. Wouldn't hurt to check the ECU codes.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby MetalupYoAss » Tue Jul 20, 2004 10:17 pm
try the injector seals (just wiggle the injectors around a bit and see if idle drops.
have you blocked the brake vacume hose too?
MetalupYoAss
Postby ee904age » Tue Jul 20, 2004 10:49 pm
Hey good point bout th einjector seals, will try that tomorrow. Cheers
And no the brake vac line is connected.
90 SW20 N/A - Sold
ee904age
Postby 86 Power » Wed Jul 21, 2004 11:18 am
Test the Cold Idle Valve?
Tape the hole at the bottom of the throttle body and start it up, but dont drive round with tape there.
The car may stall since you have the idle bypass screwed down. So wind that up and see if it idles sweet.
Then you will know you CIV is dead, or needs to be reconnected, or blocked up.
86 Power
