celica gearbox difference
Postby matsun » Wed Jul 21, 2004 10:25 pm
how do i tell the difference between a t50 box and a w55 box
matsun
Postby craufurd » Wed Jul 21, 2004 10:33 pm
the dark gb on the left is a t-50, and the two in the centre are both w boxes. noth the black sandwich plate on the w-box (its silver on the box w/o the bellhousing)
also look for the position of the clutch fork
- drivers side for t50
- passangers side for w5x
craufurd
Postby terrytuffguy » Wed Jul 21, 2004 11:58 pm
Why has one w series box got a steel plate and the other hasn't?
My 4AG powered starlet puts out 227rwkw & 12.39 @ 115mph........ YEA RIGHT, Tui.
terrytuffguy
Postby Chickenman » Thu Jul 22, 2004 3:31 am
Looks like my carport :D Fuel tank, check. Gearbox, check(only one though). Tangled wiring looms, check. Slightly beatup Toyota... getting a real engine put in :twisted: .
Baby Jesus
Chickenman
I Am The Walrus!
Postby matsun » Thu Jul 22, 2004 10:16 am
i still cant tell cos theres no clutch fork on it, are there any numbers written on the box indicating what it is, i found "W6315" on it, does that mean anything.
also does anyone have any boxes for sale
matsun
Postby wde_bdy » Thu Jul 22, 2004 6:21 pm
craufurd wrote:also look for the position of the clutch fork
This means nothing, different cars have the slave cylinder on different sides. My W55 is on the drivers side.
Easiest way to tell is the sandwich plate (the dark section, but may be silver on some boxes), if it has one most likely a W series box. What sort of car is it out of and what engine was it behind? The W series are also a lot heavier than a T series.
Callum
wde_bdy
Postby matsun » Thu Jul 22, 2004 6:47 pm
im not to sure i had it running behind a 318 v8 engine, the sandwhich plate is dark colored
matsun
Postby craufurd » Thu Jul 22, 2004 9:45 pm
wow, so i can get a w bell housing with a drivers side clutch fork? i'll finally be able to fit my exhaust in!
craufurd
Postby slonlo » Thu Jul 22, 2004 9:48 pm
w55 has 6 bolts holding the shifter turret on
t50 the shifter turret is cast in to the casing
W55
T50
have a look here for more info
http://www.reanimotion.com/ToyMods/toyo ... _Boxes.htm
http://www4.tpgi.com.au/users/loats/tec ... boxes.html
'89 LiteACE van
slonlo
