Altezza SXE10 Beams Problem
Postby Dimon » Fri Jul 23, 2004 9:27 am
Hi guys, I really hope you can help me :cry:
I have an Altezza SXE10 Beams with tiptronic transmission, for some reason, my engine light is always on when I start the car and the fly-by-wire system doesnt seem to work, basically I think the car is in "Safe Mode" and the gearbox shifts only after 5 thousand rpm, and the car is always in gear. And is real slow too. :?
I know to get more info on this I need to do special Diagnostic test, for which I have an appointment today.
If this problem sounds familiar to anyone, I would appreciate any info you could give me . Maybe even recommend a good place to go to diagnose this kind of problem.
Thanks alot
Dimon
Dimon
Postby TWSTD » Fri Jul 23, 2004 10:49 am
See my other post in this section - that may help you. You didnt just buy this car at turners did you by any chance?
Click here!
TWSTD
Postby TWSTD » Fri Jul 23, 2004 10:57 am
Click here!
TWSTD
