crank grind and polish
Postby deaf_rattle » Fri Jul 23, 2004 9:53 am
Hey, has anyone had this done before?
if so where did you go and were you happy with their work?
i might need to get my crank seen too.
Should know tonight
Postby suckymotor » Fri Jul 23, 2004 10:10 am
cant remember the name of the place but the first engine reco place on the left going down the concorse
suckymotor
TS Original Member
Postby solberg Fan » Sat Jul 24, 2004 12:03 am
I had my crank polished a week ago. only a little 4k . it cost me $30 and i couldnt even tell if they had done anything. Didnt get a grind but i dont think ill ever go there again. They took a week just to measure all my clearences (1 hours work). They found ive got a problem (told me late friday) and im stuffed for another week cos of them.
You just have to keep hassling them every day to get things done, here they are anyway...
AJ Automotive engine reconditioners. 115 wairau Rd, takapuna PH# 09 444-4213
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby evil_si » Sun Jul 25, 2004 8:06 pm
there is a few places around
a grind they take a cut off the bearing journals ths is for cranks that may have run a bearing or have deep scratches
a polish is only when they use a very fine linishing tape and polish the journals thou only normally if it has a few minor scratches, to be honest if you dont know what your looking at you probably wont be able to tell its been done
if they crank is black on the jornals it wont normally be repairable
will also pay to get it cracked tested no matter what you have done.
if you get stuck let me know i have a few machine shop contacts.
thru work i normally use franklins in pukekohe, or hdr in ash rd manukau
evil_si
Postby ChaosAD » Tue Aug 03, 2004 8:29 pm
Is 'Franklins' the same as 'franklin cam services'?
ChaosAD
Users browsing this forum: No registered users and 75 guests
