oh dear
oh dear
Postby deaf_rattle » Sat Jul 24, 2004 3:30 pm
Took the engine out last night.
THis is what i found.
what causes the bearing to do this?
Or has it simply been starved of oil at some stage?
Postby Snoop » Sat Jul 24, 2004 5:08 pm
8O J.E.S.U.S 8O
starved of oil indeed.
A plan so good my head would explode if I even began to know what I was talking about...
Snoop
Postby Chickenman » Sat Jul 24, 2004 5:35 pm
Nasty stuff 8O
Cheers for the mean wallpaper dude :wink:
Baby Jesus
Chickenman
I Am The Walrus!
Postby pidge » Sun Jul 25, 2004 12:58 am
8O
That's one crank grind and set of oversize bearing shells you'll be needing then...
pidge
Postby RS13 » Sun Jul 25, 2004 3:15 am
Yeah, I found that same problem with a 2TG I rebuilt ages ago.. the previous owner had installed forged pistons, and regularly revved it to 9000+rpm.. without modifying the factory oiling system. It had actually shat a bearing, causing the crank journal to smash itself on number 3 conrod, and numbers 2 and 4 rod bearings were identical to yours!
You have to get the crank machined, as was mentioned. I just junked my block, and bought another one.. worked out to be much cheaper. Bad luck! Causes? Lack of oil, oil pressure, incorrect clearances..
Anyways, hope you get back on the road soon. :D
RS13
Postby badidas » Sun Jul 25, 2004 11:50 am
my shells looked the same in my 16v 4age when it ran out of oil
dunno much about your engine but check the cams too as the top end would be the first to be starved for oil
1989 mazda bongo aka [BNGBUS]
badidas
Postby deaf_rattle » Sun Jul 25, 2004 12:33 pm
i might get away with a crank polish ive been told.
will know tomorrow when i take the crank in
Postby vvega » Sun Jul 25, 2004 12:35 pm
yeah i found my carnk was fine
just a polish and a new set of shells
just make sure the crank ant scored :)
v
vvega
Postby skoty » Sun Jul 25, 2004 7:24 pm
Exactly what happened to me... :?
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby pidge » Mon Jul 26, 2004 12:07 am
Oh, and check the oil galleys and the oil feed holes in the crank (I think there's some there...) are clear of crap before re-assembly.
pidge
Postby Logan » Tue Jul 27, 2004 1:10 pm
you think thats bad??? Ill post some pics of the bearings that came out of a "good runner" 2tg i brought.....
Best of luck with a rebuild, i reckon a new bottem end is alot easier, soemthing that doesnt require machine, just a new set of standard size bearings? Im guess its some form of 6? 1g or 5m or something? I guess in my case of a t block its move available...
Logan
SR Sold. Onto Other Things
Logan
Postby Logan » Thu Jul 29, 2004 11:37 am
Well these are the bearings,
pictures are pretty crap, cause they are only pxt camera ones, but you can see enough...
http://classic-celica.50megs.com/bearing1.jpg
http://classic-celica.50megs.com/bearing2.jpg
Logan
Postby CAMB01 » Thu Jul 29, 2004 11:55 pm
For deaf_rattle's bearings that really isn't caused by lack of oil, mostly just by heat and age. Trust me i know i deal with this stuff nearly everyday.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
