redtop 16v RWD conversion question.....
Postby kingcorolla » Tue Jul 27, 2004 2:43 am
on my redtop 16v there is a coolant input pipe that runs along the left hand side of the block and ends up at the back of the engine to the remote thermostat (if looking north-south) Here, there also is a couple of other feeds, (ie. heater hose, water temp sender.) For my conversion I was planning on fabricating a new pipe that "u turns" instead of running down the block, and still providing housing for thermostat, heater hose etc, but wont be easy. My other plan was just running a coolant hose from the existing thermostat, along right hand side, but was worryed about coming close to exhaust manifold, or just plain loosing cooling effiecincy! This is my 1st RWD conversion and im sure theres an easy way out. Someones done this before....hook me up!!
1983 Carina AA63 4age
kingcorolla
Postby kingcorolla » Wed Jul 28, 2004 2:13 am
U know???? FWD 4a-ge??? thermostat sits on the transaxle? whats the easiest solution for RWD conversion?? ive gotta few but i wanna hear comments.
kingcorolla
Postby AE85coupe » Wed Jul 28, 2004 1:50 pm
I just cut down the two pipes that run along the block then mounted the thermostat on that side, using random tubes to join it all up, kinda hard to explain, it was bit of a mish
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Mr Revhead » Wed Jul 28, 2004 3:56 pm
or you could buy new ae86 bits to do it, i can supply just about all of them including water pump...
Postby pacer » Wed Jul 28, 2004 7:07 pm
how much 4 all of that?
Toyota - Get the feeling
pacer
Postby kingcorolla » Wed Jul 28, 2004 11:02 pm
cheerz guys, guys its just a case of trial and error, im thinkn ov ae85 coupes idea and just cutting that pipe short and mounting thermostat as close to radiator as i can. Prob will be ruff as guts but thats the way i work. :wink: least its pretty much hidden ay! let u know how it goes.
kingcorolla
Postby gdsup » Thu Jul 29, 2004 2:06 am
i have the fwd water lines which have been shortened on my 4agze (origanally fwd)in ae86, and run the fwd thermostat housing mounted to the block below the inlet manifold, was crap when i bought the car, but a little bit of fiddling has got it working good
gdsup
Postby Mr Revhead » Thu Jul 29, 2004 10:44 am
off the top of my head $150-200 including water pump, depends on what bits you need exactly.
Postby matt dunn » Thu Jul 29, 2004 1:49 pm
gdsup wrote:i have the fwd water lines which have been shortened on my 4agze (origanally fwd)in ae86, and run the fwd thermostat housing mounted to the block below the inlet manifold, was crap when i bought the car, but a little bit of fiddling has got it working good
If i was doing it i would use a rwd 3a waterpump and rear housing and get rwd 4age top radiator hose outlet to go from the head.
Then the pipe from the back of the head and the rear of the water pump go to the heater or block them off if you are not having a heater.
Postby kingcorolla » Thu Jul 29, 2004 7:55 pm
ye, ive got one ov them RWD 3a waterpumps lyin around, thatl bolt up, itl be mint. cheerz 4 the idea matt, pretty logical wen u think about it. (do'h!) Too bad i already sent the pipe in to get fabricated :evil: :evil:
kingcorolla
Postby kingcorolla » Sat Jul 31, 2004 4:25 pm
man im an idiot
kingcorolla
