trueno gt-z blowing ecu fuse
Postby dohca » Tue Jul 27, 2004 2:18 pm
fuse under bonnet 15amp ECU one
plug new fuse in fuse is ok
until u turn the car over for about 3,5 seconds then the fuse blows and check engine light on dash goes out etc etc
this is a 4agze 145hp version with dual coils and DLI
any ideas?
dohca
Postby Sanxta » Tue Jul 27, 2004 4:19 pm
got mechanic?
Sanxta
Postby dohca » Tue Jul 27, 2004 5:30 pm
Sanxta wrote:got mechanic?
thanks for your completly irrelevant post.
im quite capable of fixing it except im asking if anyone else has had the same problem to make my life easyer...
:roll:
dohca
Postby 10k 20v » Tue Jul 27, 2004 7:30 pm
put a 4 inch nail in it :D
10k 20v
Postby 10k 20v » Tue Jul 27, 2004 7:31 pm
na seriously, i've got a mate who had the same problem on his gtz and he found the O2 sensor wire shorting out on the exhaust. It is possible you have a short elsewhere tho
10k 20v
Postby dohca » Tue Jul 27, 2004 9:58 pm
fixed it
some stupid wire from the ecu to fuse had come loose and shorted
dohca
