Where to get parts for DIY coil overs.
Postby MetalupYoAss » Tue Jul 27, 2004 10:20 pm
I wanna make some AE86 coil overs.. where can i get the threaded sleeve from and the screw fittings? Ive seen skin-fittings for boats which slightly resemble what you could use but are there any engineering shops that will just sell the sleve in lenghts or whatever?
MetalupYoAss
Postby dodgy » Wed Jul 28, 2004 8:24 am
ya cant just go to a supplier and buy the threaded tube. the best bet (frm what ive found) is to go to a mechine shop with a bit of heavy steam pipe with the correct internal diameter, and get them to chuck it in the lathe and mechine a thread on it.
ya could go to a plumbers and thry to buy some threaded stuff, but the thread needs to be real fine. UNF does the trick. and most plumbers use a coarse thread.
dodgy
Postby dodgy » Wed Jul 28, 2004 8:25 am
acually, come to think of it, i ahve seen some ads on trademe selling just the tube and lock nuts.
worth checking...
dodgy
Postby spencer » Wed Jul 28, 2004 10:07 am
stocks in aucks sell these for a reasonalbe price give there 0800 number a call I think they are around $130 a side for threaded tube and nuts etc. Should search bro I brought this up not that long ago. I think you need a 50mm inside diameter tube for ae86
ms63 crown
spencer
