kingcorolla wrote:correct me if im wrong...
i take it the 4a-gze conrods/bore width are the same as the 4a-ge,
but compression is lower due to forced induction. So is it the stroke is not as long
as the 4a-ge, ie, shorter crankshaft throws, or bigger combustion chamber in the head? Or even craters in the piston crowns?
someone tell me how they lower comp on the 4a-gze.
(i take it the conrods and the piston width are still the same if different pistons)
kingcorolla wrote:cheerz dude, guess ill go 4 the forged 4a-ge pistons then! jus wondering if 4a-gze pistons would go into 4a-ge, unless i do sum like, rip the sh*t off the head face!!![]()
Bore and stroke are identical, as are the conrods, and crank to any 7rib 4age, only thing that is different is the pistons
kingcorolla wrote:ye i got redtop (20mm)
wouldnt putting 'GZE pistons in lower compression??
kingcorolla wrote:exactly my point
ants_ae92 wrote:Intewrnals for both 4age, and 4agze are the same arent they, according to to one other post on this site it is. putting gze pistons in an na application would have to be the dumbest thing ive had all year. You will lose power, torque, and fuel efficency by doing so. Increasing the compression ratio of the motor will increase power, and fuel economy. as you won't have use as much fuel to get the same bang. eg compress same amount of air more with same fuel = more power. So going backwards by reducing c/r you are screwing yourself over for what strength. The standard na 4age pistons are very strong and dont need replacing!!
For a turbo application you are effectively increasing the compression ratio by forcing more air into a cylinder so you need the lower compression pistons. But not for a naturally aspirated application.
If you want more hp/kw in an na application try increasing the compression ratio.
4agze early(bigport) 8.0:1
4agze late(small port) 8.9:1
4age blue/ early redtop(Big port) 9.4:1
****4age Redtop smallport 10.3:1****
This is what you need. 4age redtop small port pistons. Still very strong and a higher compression ratio. 4age internals are very strong don't go backwards!!!
Someone please back me up!
kingcorolla wrote:so ur sayin that my factory pistons are capable of handling 150hp+ without even breaking a sweat? thats cool. When i posted this topic, i WANTED to know what reduced compression in a gze, so i knew what NOT to replace. But i am contemplating a gze crank and conrods for more strength, any objections??
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
