What Turbo upgrade for my Starlet???(new starlet owner)
Postby ToyGT » Sun Aug 01, 2004 8:54 pm
hey ditched my honda now i brought a Starlet
and its got a T25 turbo on it what would be a good upgrade any one done it???
thanks
ToyGT
Postby Adydas » Sun Aug 01, 2004 9:24 pm
good luck beating that.. most ppl would die to have ct9 go to T25..
i dont think you can get bigger without spending some serious cash on everything huh..
Adydas
Postby Al » Sun Aug 01, 2004 9:35 pm
t28 should use the same manifold you have currently
maybe some changing of oil/water lines tho
Al
Postby ToyGT » Sun Aug 01, 2004 10:18 pm
yeah it goes real hard at the moment
its awesome actually
just wondering what to get more power t28 sounds got what about the ball bearing t25?
what are the gear boxs like strength wise is these starlets etc... motor??
thanks peopl here it is.
i didnt do any of the work but im going to do motor up heaps more its a mess a =)
ToyGT
Postby GTUWET » Sun Aug 01, 2004 10:42 pm
thats a fukn nice example of a starlet :wink:
[GTUWET] AnD lEaViN u DRiPpIn!!
GTUWET
Postby Al » Sun Aug 01, 2004 11:22 pm
gearbox should be fine, toyota boxes arent usually prone to breaking unless you use a 20v box in a turbo car :lol:
Al
Postby boosting » Mon Aug 02, 2004 9:41 am
the good old bean machine is back 8)
boosting
Postby AXNGRL » Mon Aug 02, 2004 10:37 am
Yay for Beano's old car.... he was wondering where that ended up :)
AXNGRL
Postby Silvertop » Mon Aug 02, 2004 11:40 am
ToyGT wrote:just wondering what to get more power t28 sounds got what about the ball bearing t25?
I've never heard of a B.B T25. T25G is probably what you mean (found on early model SR20DET's, they have a bigger compressor wheel over the T25).
If you really want to upgrade the turbo T28 would be good. Same manifold, but a little bit of work involved:
New cooling lines are needed (2 water, 1 oil). Braided lines are a good investment if doing turbo swap, wouldn't rely on stock lines (esp oil).
The compressor intake flange is 90 degrees opposite to a T25, therefore will need to get a new flange made up. Or cut the intake pipe, rotate it, mark where it should go, then get it welded up.
There is a guy in Palmy who has a T28 on his Starlet. It was pretty darn laggy apparently.
Side note - if you' definately want a B.B T28 you can find them on S14 (facelifts) and S15s. GTiR's have the non-B.B turbo's and are much less of a headache come turbo recon time.
Silvertop
Postby Rollux » Mon Aug 02, 2004 1:07 pm
That's cause you can't o/haul the ball bearing centre, unless they've just developed a way recently. We had a Garrett turbo on a R50 Pathfinder let go in the bearing. Nissan said "bin it, because there is no way of fixing or replacing the bearing".
$2.5k later.....
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby beano » Mon Aug 02, 2004 5:31 pm
havnt seen my old car for a very long time.. which part of nz is it in..
cheers bean
IM NOT THAT OLD AM I??????
beano
Postby Elmendorf » Mon Aug 02, 2004 5:52 pm
:lol: good old invervegas aint it :?:
Why not post on www.starletcentral.co.nz or even do a search as heaps of ppl on there have done wicked turbo upgrades, and believe it or not most of them aint even members of this forum 8)
Elmendorf
Postby ToyGT » Mon Aug 02, 2004 8:53 pm
ok
i'll stick with the T25 for now but i'll get a 50hp NOS kit shot :D
ToyGT
Postby rollaholic » Mon Aug 02, 2004 9:20 pm
you could always try a t25 exhaust housing with t28 compressor side
sounds like you are doing pretty well tho!
Postby Al » Mon Aug 02, 2004 10:42 pm
ToyGT wrote:ok
make sure its a wet kit rather than the dry kit, ZEX seems to be on the money for nitrous using both and activation switch and a WOT switch rather than a clumsy push button for on or off.
i been looking into laughing gas myself lately 8)
Al
