oil burning
oil burning
Postby fatgtr » Mon Aug 02, 2004 7:08 pm
hey there
my car is burning oil at the moment. it only does this from cold when u step on the gas.(and when it idles a bit) i have been told its possibly the guides or piston rings. what im wanting to know is that how much oil would it generally be burning? like heaps or piss all.
any help would be appreciated
James
gotta love the punk music
fatgtr
Postby fatgtr » Mon Aug 02, 2004 7:31 pm
plz need an answer guys
James
fatgtr
Postby celica_tommo » Mon Aug 02, 2004 7:34 pm
keep an eye on your dipstick
celica_tommo
Postby badidas » Mon Aug 02, 2004 7:36 pm
check the pcv valve we had a celeca gtr that was covered in black crap from burning oil
i think the pcv valve on them was just a push in on the breather hose from the tappit cover but i cant remeber
1989 mazda bongo aka [BNGBUS]
badidas
Postby fatgtr » Mon Aug 02, 2004 8:12 pm
yeah but how would the pcv valve contribute to the oil burning?. my cars a 91 so its most likely gana burn some just hoping that it doesnt burn like a liter ever couple of weeks like my friends honda does :P
James
fatgtr
Postby badidas » Mon Aug 02, 2004 10:01 pm
BECUSE when the pdv valve doesnt do its job oil contaminates the inlet manifold and gets burned in the combustion chamber smoking like a bastard
badidas
Postby jondee86 » Thu Aug 05, 2004 10:39 pm
If your engine is in good nick it shouldn't use much more than a litre of oil between services (10,000 km).
jondee86
Watch this space >>> <<<
jondee86
Postby kingcorolla » Mon Aug 09, 2004 2:35 am
jondee86 wrote:If your engine is in good nick it shouldn't use much more than a litre of oil between services (10,000 km).
jondee86
WHAT??
if a cars in GOOD nick, and the lubrication system and the rings are doing there job, it should burn no oil, just get dirty and need replacing. Thats what the "oil control ring" is for. Keep oil out of the combustion chamber
When u work at a dealership and most of ure job is doing services, (on toyotas :D )
u know that 85% of car owners dont touch there cars and only get them serviced every 6 months/10,000km. I think if every GOOD NICK car burnt a litre of oil every 10,000km, I think there would be A LOT more mechanics around.
can i get a amen??
1983 Carina AA63 4age
kingcorolla
Postby GT 20Valve » Mon Aug 09, 2004 6:04 pm
Haha let me guess is your car a levin?
I could be wrong but those cars have a real problem with burning oil!
GT 20Valve
Postby fatgtr » Mon Aug 09, 2004 6:20 pm
na man its a celica
James
fatgtr
Postby Tofu » Mon Aug 09, 2004 6:58 pm
it really depends on how worn ur piston rings etc are.
if u are really worried why not get urself $10 and head to repco for some of that "no smoke" stuff.....it works wonders :)
then it shouldnt smoke/burn as much :)
ps. this will not FIX THE PROBLEM, just temporarily fix it till u replace what is worn.
[WAAA] - 98' JZX100 Chaser Tourer V
Tofu
Postby jondee86 » Mon Aug 09, 2004 11:19 pm
Hmmmm....... engines use oil because the valve guides need to be lubricated, the rings need to be lubricated, and some of the oil is vapourised by heat and lost through the crankcase ventilation system. This is normal. Work the engine hard and it uses more oil (ask someone who races). Use a full synthetic and you burn less. Consumption will increase as the engine wears, but a litre per 10,000 km is a useful guide.
Cheers...
jondee86
jondee86
Postby kingcorolla » Tue Aug 10, 2004 2:02 am
ahhh correct but not every car is a race car, and are driven conservitavely. and ur rite, oil does heat up and is lost through ventilation system but this does not major oil loss, if it was, then EVERY car would be built with a catch can! Same with the valve guides, not a noticable loss on the dipstick.
when engines wear they do use more oil but have u forgot, we are talking about cars in GOOD NICK, remember?
kingcorolla
Oil burning.... some figures to play with :)
Postby jondee86 » Wed Aug 11, 2004 1:59 pm
OK... let's get to the theory part !!!! Contrary to popular opinion, engines are designed to use oil. This is necessary for proper lubrication of the rings, and the "oil ring" is designed to remove excess oil from the cylinder wall, while leaving a thin film for the compression ring/s to run on. This prevents scuffing of the ring on the cylinder wall, aids ring sealing, and assists in heat transfer from the piston crown to the cylinder wall. The film of oil is evaporated/burned during the combustion process. So far so good :)
Engine manufacturers typically quote Specific Oil Consumption figures for new engines of between 1.0 g/kWh (heavily loaded) to as little as 0.1 g/kWh for a lightly loaded engine. Here we will take 0.3 g/kWh as a typical figure for a 100 kW family car. Consider this car traveling at a steady 100 k/h. It will probably be making about 25 kW.
This gives an oil consumption of 25*0.3 = 7.5 gms, and the car will have travelled 100 km. Under these conditions, after 10,000 km the engine will have used 10,000/100*7.5 = 750 gms of oil. At a SG of (say) 0.8 this will be 750/0.8 = 0.937 litres for a brand new i.e. "good nick" engine.
Of course, not everyone drives at a steady 100 k/h for 100 hours. So actual consumption will vary +/- according to conditions. Some may appear to use little oil due to lube oil dilution with fuel under cold running/short trips. But this does not mean the engine is not using oil. Lube oil dilution can lead to bearing and corrosion problems.
Now.... back to what you were doing :)
Cheers.....
jondee86
jondee86
Postby jondee86 » Wed Aug 11, 2004 2:02 pm
Cheers.....
jondee86
jondee86
Postby pplmvr » Wed Aug 11, 2004 2:35 pm
man, this has become a complicated one .. beats me.. get a new egine..
Big Is Good & Its Great to Play Together
2+3+3 = Great FUN~!
pplmvr
Regular Poster
Postby NZ_AE86 » Wed Aug 11, 2004 3:24 pm
This Jondee fella is not wrong, some euro cars (I know we are not talking about euro cars) are expected to use 3L of oil per 8K of driving, this is according to the owners manual!! WTF!! :?
All engines will use oil. Most 4AGE's will use anywhere from 500 - 1000mls between services. Even if you check the dipstick every day and it does not appear to have used any, this is because your dipstick is showing you how full you sump is of oil and whatever else is mixed in. Water or Fuel will always be contaminants in oil but it is hard to tell how much of each is present. 8O :D
NZ_AE86
Re: Oil burning.... some figures to play with :)
Postby solberg Fan » Wed Aug 11, 2004 4:31 pm
Man, i didnt realy understand that. This is what i saw:
jondee86 wrote:1.0 g/kWh, 0.1 g/kWh, 0.3 g/kWh, 100 kW, 100 k/h. 25 kW.
25*0.3 = 7.5 gms, 100 km, 10,000, 10,000/100*7.5 = 750 gms, 0.8, 750/0.8 = 0.937
100 k/h for 100 hours, +/-,
Cheers.....
jondee86
*just nod ur head and agree*
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby kingcorolla » Wed Aug 11, 2004 7:27 pm
k dude u win!
how can i compete with that? :lol:
i just thougt 1L oil per 100km was a bit drastic u know?
didnt know ul get all scientist on me! lol
kingcorolla
Postby badidas » Wed Aug 11, 2004 8:49 pm
said it b4 but ill say it again the pcv valve is most likley the problem
when there ferked it lets oil into the intake manifold and burns it causing smoking ect we had a celeca gtr do it when i was working for petermark automotive and it took a bit of time to sus out what the problem actualy was
badidas
