Anyone got wiring diagrams for a AFM ae92 4agze?
Postby dohca » Tue Aug 03, 2004 10:19 am
Cheers :0
:oops:
dohca
Postby Bazda » Tue Aug 03, 2004 10:39 am
http://www.club4ag.com/
and click on tech references
Postby dohca » Tue Aug 03, 2004 11:25 am
are these the same for the AFM version ecu?
also any one have any tips for ae86 to 4agze wiring :)
dohca
Postby IH8TEC » Tue Aug 03, 2004 7:15 pm
look under the aw11 one, as that is afm also, just has a dizzy instead of the old coil packs, (i beleive), both afm, both same everythign basically.
Postby matt dunn » Wed Aug 04, 2004 12:10 am
IH8TEC wrote:look under the aw11 one, as that is afm also, just has a dizzy instead of the old coil packs, (i beleive), both afm, both same everythign basically.
just has a dizzy instead of the old coil packs, so it absolutly completely different.
I did this conversion and found that the AE92 AFM ecu is the only one that you CANNOT find any info on.
In the end i had to get a new loom and a Map sensed ecu.
Matt
Postby dodgy » Wed Aug 04, 2004 8:40 am
i got thw wiring diagrams if ya need them.
i got 4agze diagrams from mr2, ae92
have both map and afm sets.
dodgy
Postby dodgy » Wed Aug 04, 2004 8:42 am
just put afm gze up for ya.
www.dodgymike.co.nz/4agze.pdf
dodgy
Postby dohca » Wed Aug 04, 2004 1:58 pm
you sir are a f**king ledgend!!!!
thanks heaps man.
:D :D :D :D :D :D
dohca
Postby dodgy » Wed Aug 04, 2004 4:09 pm
no probs.
good luck
dodgy
Postby IH8TEC » Wed Aug 04, 2004 6:32 pm
where did you get it, cheers man, will be very handy.
Postby dodgy » Wed Aug 04, 2004 9:44 pm
dont remember where i got it, but have been collecting wiring diagrams for most A and S series engines. from 1983 through to 1996
dodgy
Postby matt dunn » Wed Aug 04, 2004 11:58 pm
shows a block diagram of efi but not an actual specific wiring diagram showing clolurs etc does it?
Postby dodgy » Thu Aug 05, 2004 9:47 pm
sorry dude, try this one...
www.dodgymike.co.nz/Jspec4AGZE_wiring.pdf
dodgy
Users browsing this forum: Bing [Bot] and 28 guests
