3T Help!
3T Help!
Postby lvn_mr2 » Thu Aug 05, 2004 9:05 pm
Can anyone tell me where the engine mounts are on the 3T-gteu? a pic would be great but anything. next thing is, what mods can be done to this engine to give it some more ponies? 160 seems a little low compared to 112 of a 4age.
lastly, is it as easy as just adding an IC to the lines? i can fabricate new pipes and stuff.
cheers!
lvn_mr2
Postby kingcorolla » Thu Aug 05, 2004 10:41 pm
im guessing the mounts are the same place as 2t etc. may even have a support rod.
Theres enless amounts ov things u can do 2 increase power. ive hurd 3t respond well 2 a new turbo coz those factory CT20's are shithouse. and just run an i/c inbetween turbo compressor outlet and the plenum chamber.
I THINK its map sensored so no a/f/m (i think)
1983 Carina AA63 4age
kingcorolla
Postby badidas » Thu Aug 05, 2004 10:56 pm
nah man its not map sensored its got an airflow meter
my site www.freewebs.com/corolla_information has various pics
of my old 3tgte- ke70 sedan project
factory turbos are crud very minum a gtst turbo just run 14psi and it will hold togather (the turbo that is) vr4 intercooler
turbo has a bracket running to the engine mounts
hope that helps dude pm me if ya got any other questions
or try www.garagedori.com there very knowledgable on 3t/2t conversions
1989 mazda bongo aka [BNGBUS]
badidas
Postby wde_bdy » Thu Aug 05, 2004 10:58 pm
Definitely does not have an MAP sensor. Mounts are the same as most T series, they do have quite a lot of potential but you need to be careful of pistons, injectors and it really needs an intercooler. The standard computer can be tweaked reasonable easily. If you do a search there are details all over the net.
Callum
wde_bdy
Postby lvn_mr2 » Fri Aug 06, 2004 6:06 pm
ok two more questions.....are there only the two mounts on the engine? if so how hard is it to get a crossmember from say the 3tgte powered celica?
secondly do these bolt up to the t50 box?
lvn_mr2
Postby wde_bdy » Fri Aug 06, 2004 6:16 pm
What sort of car are you putting it in?
For the T50 box I think you need an ordinary T series flywheel/clutch/pressure plate, the 3T-GTE one is bigger and has a different clutch.
Callum
wde_bdy
Postby badidas » Fri Aug 06, 2004 6:58 pm
there are 2 engine mounts like purple beasty said a t50 bolts up with
a t series bell housing and possibly 2tgeu flywheel and clutch (not sure)
t50 wont last very long at all your better off using a w55,57,58 from ta63 celeca and supras
what shape celeca ar you planning on putting a 3t into ?
badidas
