ke30 -> 4agze conv?
ke30 -> 4agze conv?
Postby Levin111 » Sat Aug 07, 2004 12:18 am
hey guys, im thinking of buyin a ke30 real soon, would like to know what i need to do for a 4agze conv.
need to know what parts i need to use, diffs, gear boxed , cross member.
not experienced with old school corollas yet, but sure would like to learn.
can anyone plz help me, any one with a ke30 etc. cheers
New Profile Update:~
http://toyspeed.blakjak.net/profiles/profile.php?id=298
Past rides
Levin Ae11 BZ-G
Rx7 S6 13b REW
Mazda 929 wagon
Rx7 S4 13b Extend port turbo (Current)
Levin111
Postby kingcorolla » Sat Aug 07, 2004 1:12 am
ke30's come factory with 3k's, so u need a crossmember and mounts from and ae86 or an ae70 to fit the 'gze. Then u need a g/box with an a-series bellhousing, u got either k50 (weakest and common), t50 (stronger and hard to find with a series bellhousing) The strongest would be the "w" series boxes, which u will find on 86 supras, cressidas, crowns etc. mostly m series engines. but this box is no simple boltup, and will need an adapter plate for different bellhousing, or custom bellhousing. Ure driveshaft may need customizing due to different engine/box length and different differential. As for the diff, there are several options u have. u could fork out and find an lsd or sum but i prefer to be creative and change the hole live axle, toyota hilux rear axles are are common choice due to tough diffs, but it will have to be narrowed and have new mounts fabricated to fit. Chuck on some rear disc brakes while ure at it.
just search the net for some sites ov peoples conversions. Theres heaps ov great sites out there
just do a google search or sum.
1983 Carina AA63 4age
kingcorolla
Postby Levin111 » Sun Aug 08, 2004 12:09 pm
cheers dude, thank for the info, ill check the stuff tonight
Past rides
Levin Ae11 BZ-G
Rx7 S6 13b REW
Mazda 929 wagon
Levin111
Postby l1ttle_d3vil » Sun Aug 08, 2004 12:52 pm
http://www.users.bigpond.com/vidore/toy ... engine.htm
that might be some help to you, mostly for 4ages though but there should still be some relevant stuff in there for you.
Users browsing this forum: Bing [Bot] and 23 guests
