supercharger oil
supercharger oil
Postby AE101Z » Sat Aug 07, 2004 2:46 am
does anyone know how to change the supercharge oil??
AE101Z
sc
Postby JasonZE » Sat Aug 07, 2004 11:44 am
There is a drain bung at the bottom and the yellow wing nut on the top is the filling point and dipstick.
Not easy to get at and if the oil is clean I wouldnt bother changing it as is only lubricates the gears at the back of the s/c unit and the oil is expensive.
Top it up if its a bit low.
JasonZE
Real Life Mechanic
Postby aesc » Sat Aug 07, 2004 1:56 pm
That drain bung is a bitch to get to.
If you buy the genuine toyota stuff you get a syringe with it, so you suck the old oil out with it and push the new oil back in with it.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Lloyd » Sat Aug 07, 2004 3:25 pm
In saying that, the filling hole is a bitch to get at also. Specially if its on tight
Postby badidas » Sat Aug 07, 2004 6:57 pm
if ur in auckland and lazy ill do it for $15 and ask someone on here if u can buy there left over extra s/c oil
1989 mazda bongo aka [BNGBUS]
badidas
