ECU Suggestion
ECU Suggestion
Postby Lloyd » Sun Aug 08, 2004 1:44 pm
Can anyone recommend a decent piggyback system for a 4AGTE? As much as I would like to get a LEM4 its just too much money right now. Engine-wise its prettymuch finished but I'm a little worried about fueling (running 10psi to start with is the plan).
Other question, if I simply put in these 440cc VR4 injectors (yes, low impedance like the GTZ ones I'm using at the moment) would that prevent leaning out on 10psi with stock computer or would it overfuel a bit too much to run properly?
As I said, everything is pretty much sorted as far as the engine goes, just wanting to make sure the fueling side of things isn't going to let me down
Cheers for any advice
btw, I've had a search and read through a few thread regarding full engine management system on here and didn't find what I wanted to know.
Postby atmosports » Sun Aug 08, 2004 2:53 pm
There really is no such thing as a cheap piggyback, you'd be better off to save your $$$ & buy a Link or similar, that will control fuel/spark & boost as you'll get a more driveable car that will generally produce better/more consistent results & be easier to tune. A LEM V4 installed & tuned should set you back around $2k depending on extras, that paying for an install & tuning.
If you put the 440cc injectors in it may or may not be lean at the top end on 10psi boost, have you upgraded the pump/regulator/lines etc to handle the extra fuel needed. It will if it even runs be rich as $&#$% at idle, you could possibly get away with running a rising rate regulator to help even the mixtures out but I doubt you will get a satisfactory idle/low rpm setup.
atmosports
Postby Bazda » Sun Aug 08, 2004 10:05 pm
apparantly FLAWLES has found some piggy back computer that his uncle brings in from over in the states, he installed one of his ae101 gtz and said it works extremly well and he is very happy with it.
But he hasnt got back to me with a price yet, so will let u know when he does.
Postby matt dunn » Sun Aug 08, 2004 10:29 pm
Bazda wrote:apparantly FLAWLES has found some piggy back computer that his uncle brings in from over in the states, he installed one of his ae101 gtz and said it works extremly well and he is very happy with it.
If you want a link I can do a second hand one fitted to your car for th same price as a new one. Presuming your in Dunedin so I'm in timaru which is travelling distance. PM me if you want to check out this option.
Matt
Postby Lloyd » Sun Aug 08, 2004 10:58 pm
Hmmmm.... that sounds like an offer I really want to take. I just have to get a final price of what the engine stuff is gonna be costing me before I know how much money I'll have to play with. If you've still got it in a couple of week I might be keen on that offer Matt
And I'd quite like to know what they're worth too Bazda. And damn you for making me want to paint my car now :P
